Component: Input ADC (DSP Inputs)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Inputs
Input ADC component
Allows the values from a buffer to be assigned driectly from an analog enabled pin. Either a single sample at a time or a number of samples. Auto scales the digital value to fill the entire range of the specified buffer type.
Please click here to download the component source project: FC_Comp_Source_DSP_ADCInput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_ADCInput.fcfx
AddSample
Adds a single ADC sample to the current location in the specified buffer. If Auto Scale is enabled then the sample will be scaled to correctly fit inside the buffer. Auto increments current location.
AddSampleArray
- UINT SampleDelay
Number of us in between each sample.
Buffer Size
Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Settings
Auto Adjust Scale
Yes: Automatically convert ADC samples to match the full bit depth of the DSP buffer. No: Leave the ADC samples at the native bit depth.
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Maximum number of bits for each ADC sample.
AddSample
AddSampleArray
- UINT SampleDelay
Buffer Size
Buffer Type
Settings
Auto Adjust Scale
VRef option
Conversion speed
Acquisition cycles
Bit Depth
AddSample
AddSampleArray
- UINT SampleDelay
Buffer Size
Buffer Type
Settings
Auto Adjust Scale
VRef option
Conversion speed
Acquisition cycles
Bit Depth
