Component: Input CSV (DSP Inputs)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Inputs
Input CSV component
Allows the values from a buffer to be collected directly from a CSV file. Either a value at a time or from an array.
Please click here to download the component source project: FC_Comp_Source_DSP_FileInput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_FileInput.fcfx
Fc9-comp-macro.png CloseFile
Closes a file
Fc9-comp-macro.png OpenFile
Opens a file ready for reading. Returns 1 if file opened correctly. Automatically called by the ReadValue/ReadArray macros with the default values set by the component properties if not already called by the program.
Fc9-comp-macro.png ReadArray
Reads an array of values to fill up the specified buffer. FAT component must be initialised before calling this macro. Returns 0 when we are at the end of the file, else returns 1.
Fc9-comp-macro.png ReadValue
Reads a value from the current row in the CSV file. FAT component must be initialised before calling this macro. Returns 0 when we are at the end of the file, else returns 1.
Fc9-type-21-icon.png Buffer Size 0
Fc9-type-16-icon.png Buffer Type 0
Fc9-conn-icon.png CSV File
Fc9-type-16-icon.png LinkTo
Fc9-type-10-icon.png Filename
Name of the file to read DSP data from.
Fc9-type-16-icon.png Number of Outputs
The number of outputs the CSV reader can provide. Each output will be driven by the corresponding column of the CSV file.
Fc9-type-16-icon.png End of File
Determines what happens when we hit the end of the input file. The return value from the ReadValue/ReadArray can be checked to allow the file end to be caught and actioned.
Closes a file
Closes a file
