Component: RFID (BL0197) (E-blocks 2)
| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | E-blocks 2 |
RFID (BL0197) component
Low level routines for controlling a BL0197 RFID E-block 2 board. Complete with macros to control the tag type and buzzer parameters.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_RFID_BL0197.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_RFID_BL0197.fcfx
| GetRFIDTypeID | |
| Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module. | |
| SetCardType | |
| Allows the RFID tag type to be configured | |
| TagType | |
| 0 = MIFARE, 1 = ICODE, 2 = ISO14443B | |
| WriteRFIDBlock | |
| Writes a block of information to the RFID device. | |
| Address | |
| Remote RFID Block Address. | |
| Key_Type | |
| WriteRFIDModule | |
| Stores a byte of data to the internal EEPROM of the RFID module at the address specified. | |
| Address | |
| Data | |
| DecrementRFIDValue | |
| Perfoms a 32-bit decrement on the number held in location page or block. | |
| Src | |
| Page / Block | |
| Dst | |
| Page / Block | |
| Key_Type | |
| Needed for MIFARE Commands | |
| FormatRFIDValue | |
| Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command. | |
| IncrementRFIDValue | |
| Perfoms a 32-bit increment on the number held in location page or block. | |
| Src | |
| Page / Block | |
| Dst | |
| Page / Block | |
| Key_Type | |
| WriteRFIDBuffer | |
| Writes a byte of data to the outgoing buffer. | |
| Address | |
| The address of the buffer 0 - 15 | |
| Data | |
| The data to be stored in the buffer location 0 - 255. | |
| GetRFIDStatus | |
| Collect the status of the RFID device (see help for the explaination of the status byte). | |
| ReadRFIDBuffer | |
| Reads a byte of data from the incoming buffer. | |
| Address | |
| GetRFIDUID | |
| Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module. | |
| ReadRFIDUID | |
| Reads a byte of data from the UID buffer. | |
| Address | |
| The address of the buffer 0 - 7 | |
| IsTagPresent | |
| Checks to see if a card is present. Returns 0 if no tag is present. Returns 1 if a valid tag is present. | |
| SetBeep | |
| Allows the buzzer output to be configured | |
| BeepDelay | |
| 0 = Off, 1 = 40mS, 2 = 80mS, 3 = 120mS etc. | |
| ReadRFIDBlock | |
| Reads a block of information from the RFID device. | |
| Address | |
| Key_Type | |
| Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties. | |
| GetRFIDTypeID | |
| SetCardType | |
| TagType | |
| WriteRFIDBlock | |
| Address | |
| Key_Type | |
| WriteRFIDModule | |
| Address | |
| Data | |
| Src | |
| Page / Block | |
| Dst | |
| Page / Block | |
| Key_Type | |
| FormatRFIDValue | |
| Src | |
| Page / Block | |
| Dst | |
| Page / Block | |
| Key_Type | |
| WriteRFIDBuffer | |
| Address | |
| Data | |
| GetRFIDStatus | |
| ReadRFIDBuffer | |
| Address | |
| GetRFIDUID | |
| ReadRFIDUID | |
| Address | |
| IsTagPresent | |
| SetBeep | |
| BeepDelay | |
| ReadRFIDBlock | |
| Address | |
| Key_Type | |
| GetRFIDTypeID | |
| SetCardType | |
| TagType | |
| WriteRFIDBlock | |
| Address | |
| Key_Type | |
| WriteRFIDModule | |
| Address | |
| Data | |
| Src | |
| Page / Block | |
| Dst | |
| Page / Block | |
| Key_Type | |
| FormatRFIDValue | |
| Src | |
| Page / Block | |
| Dst | |
| Page / Block | |
| Key_Type | |
| WriteRFIDBuffer | |
| Address | |
| Data | |
| GetRFIDStatus | |
| ReadRFIDBuffer | |
| Address | |
| GetRFIDUID | |
| ReadRFIDUID | |
| Address | |
| IsTagPresent | |
| SetBeep | |
| BeepDelay | |
| ReadRFIDBlock | |
| Address | |
| Key_Type | |
