| Author
Matrix Ltd
| Version
2.0
| Category
E-blocks 1
GLCD (EB075) component
Graphical display component designed to work with the Goldelox range of displays from 4D Systems. Also available in the form of the EB075 GLCD E-block.
Please click here to download the component source project: FC_Comp_Source_GLCD_4D_EB075.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_4D_EB075.fcfx
EB075 gLCD Example File
EB075 Example
G4D_InitialiseCard
| Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure. Does not currently simulate.
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
| Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
G4D_DisplayVideoFromCard
| Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
G4D_ReadJoystickGoldelox
| Reads the value of the joystick input. 0 = No press detected / 1 = Up Pressed / 2 = Left Pressed / 3 = Down Pressed / 4 = Right Pressed / 5 = Fire Pressed
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
G4D_DisplayImageFromCard
| Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
AddH
| Byte Address High Word
- UINT
AddL
| Byte Address Low Word
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Reset Pin
| Reset pin connection
Baud Options
| Baud rate option selector
Component Label
Component Label Scale
Physical Orientation
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
G4D_InitialiseCard
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
Reset Pin
Baud Options
Component Label
Console Columns
Data Source
G4D_InitialiseCard
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
Reset Pin
Baud Options
Component Label
Console Columns
Data Source
