Component: GLCD (Grove OLED) (OLED 1.12") (Graphical Monochrome)
Revision as of 15:21, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (Grove OLED) component
Graphical display component based on the Seed Studio Grove OLED 1.12" and 0.96" monochrome displays. Functions without the use of a read back by hosting the graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_Grove_OLEDDisplay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_Grove_OLEDDisplay.fcfx
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-comp-macro.png ControlContrast
Sets the display contrast from 0 to 255.
Fc9-u8-icon.png - BYTE Contrast
Range 0 - 255, Default 207
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png InvertDisplay
Fc9-conn-icon.png Display Type
Fc9-type-16-icon.png Display Version
Fc9-type-7-icon.png Use Buffer
The buffer is used to store the display pixel data so that we can write new content to the display without effecting adjacent pixels. With the buffer disabled there is a high chance of display corruption. For example if drawing text that is not using a multiple of 8 pixels for the y axis. e.g. 0, 8, 16, 24 etc.
Number of bytes used to buffer the display contents.
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png SDA
Baud rate to be used
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Used to drive the comms durig simulation which can be used to: Data Recorder waveform generation Console Logging Data Injector to redirect the data e.g. to a SCADA slave connected to the physical hardware
0=Off, 1=On
0=White, 1=Black
0=White, 1=Black
Channel selection
0=Off, 1=On
0=White, 1=Black
0=White, 1=Black
Channel selection
