Component: GLCD (SSD1327) SPI (SSD1327) (Graphical Monochrome)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.9
Category Graphical Monochrome
GLCD (SSD1327) SPI component
Graphical display component based on the SPI version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1327_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1327_SPI.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SendCommand
- BYTE Command
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
ControlDisplay
Allows the display to be switched on and off
- BYTE Control
0=Off, 1=On
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
Refresh
Refreshes the entire display by sending the contents of the local RAM to the display at high speed
SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE Shade
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Flip
Determines if the display is flipped or not
Auto Draw
Yes: Default - Lines, Text, Clear will all be done automatically No: Data will be sent only to the internal RAM, the display will be updated using the Refresh command
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
DC Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
Simulate Comms
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Communications
API
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SendCommand
- BYTE Command
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
ControlDisplay
- BYTE Control
0=Off, 1=On
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
Refresh
SetShadeIntensity
- BYTE Shade
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Flip
Auto Draw
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Prescale
MOSI
MISO
CLK
CS / SS
DC Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Simulate Comms
Communications
API
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SendCommand
- BYTE Command
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
ControlDisplay
- BYTE Control
0=Off, 1=On
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
Refresh
SetShadeIntensity
- BYTE Shade
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
InvertDisplay
Dimensions
Pixel Width
Pixel Height
Flip
Auto Draw
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Prescale
MOSI
MISO
CLK
CS / SS
DC Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Simulate Comms
Communications
API
