Component: I2C Multiplexer (TCA9548A) (Comms: System)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
I2C Multiplexer (TCA9548A) component
An I2C multiplexing IC allowing up to 8 different I2C busses to be connected to a single I2C channel on your target microcontroller.
Please click here to download the component source project: FC_Comp_Source_I2C_Multiplexer_TCA9548A.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Multiplexer_TCA9548A.fcfx
Here we have a simple example showing how to use the multiplexer to connect multiple of the same I2C sensor IC to the microcontroller.
The multiplexer IC is connected directly to the microcontroller I2C pins and up to 8 temp/humidity sensors are connected to the CH0-CH7 I2C pins of the multiplexer.
I2C Multiplex Example
SelectChannel
Selects a single output channel to multiplex the I2C output to (0-7).
- BYTE Channel
Range: 0-7
SetChannelMask
Allows a user determined number of channels to be connected to the I2C bus.
- BYTE Mask
Range: 0-255 / Bit0=CH0 EN / Bit1 = CH1 EN etc
Startup the I2C bus ready for communications.
Multiplexer Properties
Address Bits
I2C Properties
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
SelectChannel
- BYTE Channel
Range: 0-7
SetChannelMask
- BYTE Mask
Address Bits
I2C Properties
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
SelectChannel
- BYTE Channel
Range: 0-7
SetChannelMask
- BYTE Mask
Address Bits
I2C Properties
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
