Component: I2S Master/Slave ESP32 (Comms: Interface)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Interface
I2S Master/Slave ESP32 component
Provides access to the onboard inter-IC sound (I2S) peripheras allowing for simple digital audio input and output.
Please click here to download the component source project: FC_Comp_Source_I2S.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2S.fcfx
Stop
Stops the I2S audio stream
Read
Wait timeout ticks to receive length number of samples, returns samples received. 24 and 32-bit data must be split into two integer values per sample.
- INT Data
Data array to populate with incoming data
- UINT Length
Max number of samples to try and receive
- UINT Timeout
Max number of ticks to wait for incoming samples
CheckQueue
Checks the I2S Event queue for a DMA Buffer full or empty event. For an output returns true when there is an empty DMA buffer available. For an input return true when there is a full DMA buffer available.
- BOOL Return
Write
Wait timeout ticks to send length number of samples, returns samples sent 24 and 32-bit data must be split into two integer values per sample.
- INT Data
Data array containing outgoing data
- UINT Length
Max number of samples to try and send
- UINT Timeout
Max number of ticks to wait for space in the outgoing buffer
Start
Starts the I2S audio stream, auto started by the initialise function.
Configures the I2C peripheral ready for data.
DAC Channel number
Clock Pin
I2S Clock Pin
Serial Data Pin
I2S Serial Data (SD) Pin
Word Select Pin
I2S Word Select (WS) Pin
Mode
Configures if the I2S peripheral is a master or slave on the bus.
Data Direction
Controls if the I2S data is coming in or out of the microcontroller
Audio Channels
Number of distinct audio channels in the data stream
Sample Rate
Audio sample rate in Hz
Data Bits
Nmber of bits in each audio sample
DMA Buffer Count
I2S DMA Buffer Count
DMA Buffer Size
I2S DMA Buffer Size
Stop
Read
- INT Data
- UINT Length
- UINT Timeout
CheckQueue
- BOOL Return
Write
- INT Data
- UINT Length
- UINT Timeout
Start
DAC Channel number
Clock Pin
I2S Clock Pin
Serial Data Pin
Word Select Pin
Mode
Data Direction
Audio Channels
Sample Rate
Data Bits
DMA Buffer Count
DMA Buffer Size
I2S DMA Buffer Size
Stop
Read
- INT Data
- UINT Length
- UINT Timeout
CheckQueue
- BOOL Return
Write
- INT Data
- UINT Length
- UINT Timeout
Start
DAC Channel number
Clock Pin
I2S Clock Pin
Serial Data Pin
Word Select Pin
Mode
Data Direction
Audio Channels
Sample Rate
Data Bits
DMA Buffer Count
DMA Buffer Size
I2S DMA Buffer Size
