Component: J1939 (Misc)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Author
Version 1.1
Category Misc
J1939 component
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
Check
Returns 0 if running on an embedded target or 1 if running in simulation runtime.
- BOOL Return
Sim
Rx_Transfer_Data
Returns the byte count and data of the transfer message data
- BYTE DataBuffer
Buffer to receive copied data
- UINT Size
Size (byte count) of buffer
Message_Data_Read_SPN
Read the SPN value from the CAN data buffer
- UINT SPN
- BYTE DataBuffer
Process
Does the message processing. Call this often.
- UINT TimeElapsed
Time elapsed since last call, in mS. Can be zero for frequent calling.
Rx_Transfer_Check
Check for incoming multipart data transfers. If received, returns the PGN else 0
- ULONG Return
Get_Address
Returns the device (ECU) actual address
Message_Data_Set
Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF
- BYTE DataBuffer
- BYTE Value
Tx_Transfer_Send
Send a mulitpart data transfer message. Returns number of bytes accepted. Limited by max message size.
- ULONG PGN
Multipart message program number
- BYTE Data
Data buffer to send
- UINT Size
Number of data bytes to send
Rx_Message_Check
If a data message has been received returns the PGN,otherwise 0
Get_Status
Returns the system status. 0 = Ready. 1 = Waiting address claim
Message_Data_Write_SPN
Write the SPN value to the CAN data buffer
- UINT SPN
- UINT Value
- BYTE DataBuffer
Rx_Message_Data
Returns the DLC and data of the last received message
- BYTE DataBuffer
Tx_Message_Send
Send the prepared CAN message
- UINT PGN
- BYTE DLC
- BYTE DataBuffer
Message_Data_Clear
Clear the CAN Data Buffer
- BYTE DataBuffer
Rx_Message_Source
Returns the Source Address of the last received message
Initialise the CAN network and J1939 protocol
- BYTE Preferred_Address
Preferred Address (Requested Address)
NAME
Industry Group
Vehicle System Instance
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
Transmit Message Buffer Size
Byte buffer size to allocate for transmitted multipart messages. Maximum is 1785 or available RAM
Receive Message Buffer Size
Byte buffer size to allocate for received multipart messages. Maximum is 1785 or available RAM
CAN
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Controller Osc
Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
SPI
CHANNEL
SPI Channel selector
MOSI
MISO
CLK
SS
Prescale
Prescale option selector
Sample Point
Data bit read sample point
Config Delay
Rx_Transfer_Data
- BYTE DataBuffer
- UINT Size
- UINT SPN
- BYTE DataBuffer
Process
- UINT TimeElapsed
Rx_Transfer_Check
- ULONG Return
Get_Address
Message_Data_Set
- BYTE DataBuffer
- BYTE Value
Tx_Transfer_Send
- ULONG PGN
- BYTE Data
Data buffer to send
- UINT Size
Rx_Message_Check
Get_Status
- UINT SPN
- UINT Value
- BYTE DataBuffer
Rx_Message_Data
- BYTE DataBuffer
Tx_Message_Send
- UINT PGN
- BYTE DLC
- BYTE DataBuffer
Message_Data_Clear
- BYTE DataBuffer
Rx_Message_Source
NAME
Industry Group
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
CAN
Controller Osc
Bus Rate
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
Rx_Transfer_Data
- BYTE DataBuffer
- UINT Size
- UINT SPN
- BYTE DataBuffer
Process
- UINT TimeElapsed
Rx_Transfer_Check
- ULONG Return
Get_Address
Message_Data_Set
- BYTE DataBuffer
- BYTE Value
Tx_Transfer_Send
- ULONG PGN
- BYTE Data
Data buffer to send
- UINT Size
Rx_Message_Check
Get_Status
- UINT SPN
- UINT Value
- BYTE DataBuffer
Rx_Message_Data
- BYTE DataBuffer
Tx_Message_Send
- UINT PGN
- BYTE DLC
- BYTE DataBuffer
Message_Data_Clear
- BYTE DataBuffer
Rx_Message_Source
NAME
Industry Group
Vehicle System
Function
Function Instance
ECU Instance
Manufacturer Code
Identity Number
CAN
Controller Osc
Bus Rate
SPI
CHANNEL
MOSI
MISO
CLK
SS
Prescale
Sample Point
Config Delay
