Component: LED (EB004) (E-blocks 1)
| Version | 1.1 |
| Category | E-blocks 1 |
LED component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to download the component source project: FC_Comp_Source_LED_Array_EB004.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_EB004.fcfx
|   | BarGraph |
| Turns on the first N elements of the array - for generating bar graph metes etc. | |
|  - BYTE | Length |
| How many items to light up. | |
|  - VOID | Return |
|   | LEDOn |
| Turn on the selected LED. | |
|  - BYTE | Index |
| Index of the LED to turn on. | |
|  - VOID | Return |
|   | AllOn |
| Turns on all elements | |
|  - VOID | Return |
|   | LEDOff |
| Turn off the selected led. | |
|  - BYTE | Index |
|  - VOID | Return |
|   | PointGraph |
| Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range. | |
|  - BYTE | Index |
| The LED to show. | |
|  - VOID | Return |
|   | WriteValue |
| Write a number which is presented on the LEDs in binary. | |
|  - BYTE | Value |
| Provide a value to be written to the LEDs in binary | |
|  - VOID | Return |
|   | AllOff |
| Turns off all elements | |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Output Mode |
| Choose a single port for all LEDs, or to allocate them to arbitrary pins. | |
|   | Port |
|   | BarGraph |
|  - BYTE | Length |
|  - VOID | Return |
|   | LEDOn |
|  - BYTE | Index |
|  - VOID | Return |
|   | AllOn |
|  - VOID | Return |
|   | LEDOff |
|  - BYTE | Index |
|  - VOID | Return |
|   | PointGraph |
|  - BYTE | Index |
|  - VOID | Return |
|   | WriteValue |
|  - BYTE | Value |
|  - VOID | Return |
|   | AllOff |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Output Mode |
|   | Port |
|   | BarGraph |
|  - BYTE | Length |
|  - VOID | Return |
|   | LEDOn |
|  - BYTE | Index |
|  - VOID | Return |
|   | AllOn |
|  - VOID | Return |
|   | LEDOff |
|  - BYTE | Index |
|  - VOID | Return |
|   | PointGraph |
|  - BYTE | Index |
|  - VOID | Return |
|   | WriteValue |
|  - BYTE | Value |
|  - VOID | Return |
|   | AllOff |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Output Mode |
|   | Port |
