Component: Magnetometer (SM324) (Movement Orientation)
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Category Movement Orientation
Magnetometer (SM324) component
SM324 ultraprecise 24-bit smart magnetometer capable of distance measurement using a magnet. Controlled via I2C bus communications.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_SM324.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_SM324.fcfx
ReadStatus
Reads the status byte from the sensor IC. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation
WriteMemory
Writes a 16-bit value to the specified memory location
- BYTE Address
Internal memory address
- UINT Value
RequestData
Requests temperature and magnetic data from the device, returns status. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation
ReadTemperatureRaw
Reads the temperature from the last succesful data read.
- LONG Return
ReadMagneticFieldRaw
Reads the magnetic field from the last succesful data read.
- LONG Return
ReadMagneticFieldReal
Reads the magnetic field from the last succesful data read as a float in Oersted Oe.
- LONG Return
SetAddress
Configures the device address used to communicate with sensor IC. Optionally writes the new address to the sensor IC NVM.
- BYTE Address
The new address of the sensor IC, Range 8-127
- BOOL WriteToIC
Writes the new address to the IC NVM 1=Write, 0=Don't Write
WriteCommand
Sends a command to the sensor IC.
- BYTE Command
ReadTemperatureReal
Reads the temperature from the last succesful data read as an float in degrees C.
- FLOAT Return
Sets up the I2C bus ready to communicate with the sensor IC. Sets the address variable back to the Address property value.
Sensor Properties
Cyclic Mode
I2C Properties
Channel selection
Address
Address of the SM324 IC, Default address is 16. Valid Address range = 8 to 127
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Baud rate to be used
Threshold Output
Threshold Pin
The pins used to check the DOUT pin on the SM324,
Threshold Setting
Controls the function of the sensor IC DOUT pin.
Threshold1
Threshold 1 Value
Threshold2
Threshold 2 value. If Thresh1 > Thresh2 1: Measurement > Thresh1 OR Measurement < Thresh2 0: Thresh1 > Measurement > Thresh2 If Thresh2 > Thresh1 1: Thresh1 > Measurement > Thresh2 0: Measurement > Thresh2 OR Measurement < Thresh1
Simulate Comms
ReadStatus
WriteMemory
- BYTE Address
- UINT Value
RequestData
ReadTemperatureRaw
- LONG Return
- LONG Return
- LONG Return
SetAddress
- BYTE Address
- BOOL WriteToIC
WriteCommand
- BYTE Command
ReadTemperatureReal
- FLOAT Return
Sensor Properties
Cyclic Mode
I2C Properties
Channel selection
Address
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Threshold Output
Threshold Pin
Threshold Setting
Threshold1
Threshold 1 Value
Threshold2
Simulate Comms
ReadStatus
WriteMemory
- BYTE Address
- UINT Value
RequestData
ReadTemperatureRaw
- LONG Return
- LONG Return
- LONG Return
SetAddress
- BYTE Address
- BOOL WriteToIC
WriteCommand
- BYTE Command
ReadTemperatureReal
- FLOAT Return
Sensor Properties
Cyclic Mode
I2C Properties
Channel selection
Address
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Threshold Output
Threshold Pin
Threshold Setting
Threshold1
Threshold 1 Value
Threshold2
Simulate Comms
