| Author
Matrix TSL
| Version
1.0
| Category
Indicators
Numeric Label component
Allows a numeric label to be displayed on the user panel. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
Please click here to download the component source project: FC_Comp_Source_NumericLabel.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_NumericLabel.fcfx
DisplayAsReal
| Displays a floating point value on the label with a confiiguarable number of decimal points
- FLOAT
Value
| Real floating point value to display
- BYTE
Precision
| Number of decimal point values to show e.g. 2 = 0.00
SetForegroundColour
| Allows the user to manually specify the default colour of the foreground text.
- LONG
Colour
| RGB colour in the hexadecimal form 0xBBGGRR, -1 for Transparent
DisplayAsInt
| Displays an integer value on the label. Capable of displaying positive and negative values.
- LONG
Value
| Integer value to display
SetUnits
| Allows the user to manually specify the units string that is appended to the end of the label.
- STRING
Units
Title
Show Title
| Decides if the title is shown on the panel.
Title Text
| Specifies the title displayed on the panel.
Title Scale
| Specifies the size of the title on the panel, default 1.2
Title Colour
| Specifies the colour of the title text
Title Offset
| Distance above component center to draw the title
Label Properties
Label Scale
| Specifies the scale of the label text, default 1.0
Show Units
| Specifies if the unit text is appended to the end of the numeric value
Unit Text
| Optionally adds a unit label to the end of the displays string
Colour Ranges
| Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Defaults
Numeric Colour
| The label Text colour
DisplayAsReal
- FLOAT
Value
- BYTE
Precision
SetForegroundColour
- LONG
Colour
DisplayAsInt
- LONG
Value
SetUnits
- STRING
Units
Title
Show Title
Title Text
Title Scale
Title Colour
Title Offset
Label Properties
Label Scale
Show Units
Unit Text
Colour Ranges
Defaults
Numeric Colour
DisplayAsReal
- FLOAT
Value
- BYTE
Precision
SetForegroundColour
- LONG
Colour
DisplayAsInt
- LONG
Value
SetUnits
- STRING
Units
Title
Show Title
Title Text
Title Scale
Title Colour
Title Offset
Label Properties
Label Scale
Show Units
Unit Text
Colour Ranges
Defaults
Numeric Colour
