Component: Property Manager (Utility )
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Category Utility
Property Manager component
Allows property values exposed to the user to be saved and loaded using an external file. Simplifies the process of storing and retreiving the property values. Also works with nested properties using the "::" syntax.
Please click here to download the component source project: FC_Comp_Source_PropertyManager.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_PropertyManager.fcsx
Save
Saves the registered property values to the config file.
Load
Loads the registered property values from the config file.
RegisterProperty
Registers a property to be saved or loaded
- STRING PropertyVariable
Property variable exposed to the user, highlight property and variable is shown at the bottom of the window.
Filepath
Sets the path of the file to write to. $(srcdir) default sets the path to be the same as the Flowcode project path.
Filename
Show Dialogue On Load
Forces the user to check if they are sure before loading saved values.
Show Dialogue On Save
Forces the user to check if they are sure before overwriting previous values.
Save
Load
RegisterProperty
Filepath
Filename
Save
Load
RegisterProperty
Filepath
Filename
