Component: Rotary Switch (Switch)
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Category Switch
Rotary Switch component
A standard rotary switch with 4 digital outputs and 10 or 16 discrete positions.
Please click here to download the component source project: FC_Comp_Source_RotarySwitch10-16.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RotarySwitch10-16.fcfx
SetPosition
Sets the current position of the rotary switch.
- BYTE Position
GetPosition
Reads the current position of the rotary switch.
Num Positions
Common Type
Pins
Pin 1
Pin 2
Pin 4
Pin 8
SetPosition
- BYTE Position
GetPosition
Num Positions
Common Type
Pins
Pin 1
Pin 2
Pin 4
Pin 8
SetPosition
- BYTE Position
GetPosition
Num Positions
Common Type
Pins
Pin 1
Pin 2
Pin 4
Pin 8
