Component: Standard Deviation (Calculation)
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Calculation
Standard Deviation component
A set of functions used to calculate the mean and standard deviation on a set of data samples.
Please click here to download the component source project: FC_Comp_Source_StandardDeviation.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_StandardDeviation.fcfx
InitialiseFIFO
initialises the first in first out buffer values to 0
AddSample
Adds a sample to the first in first out sample buffer.
- FLOAT Sample
Value to add into the FIFO buffer
GetMean
Gets the mean of the values in the first in first out buffer
- FLOAT Return
GetDeviation
Gets the standard deviation of the values in the first in first out buffer
- FLOAT Return
SetSampleCount
Sets the number of samples when using the variable sample count type.
- UINT SampleCount
Sample Count Type
Controls if the number of samples to determine the mean and deviation are fixed or variable, Fixed has some additional optimisations when adding samples but variable allows flexibility. The sample count for variable samples defaults to the max count and can be set using the SetSampleCount macro.
Number of Samples
Fixed number of samples used to calculate the mean and deviation. Samples are first in first out so the newest sample will replace the oldest.
Initial Sample Value
Sets the initial value of each sample when initialising the FIFO.
InitialiseFIFO
AddSample
- FLOAT Sample
GetMean
- FLOAT Return
GetDeviation
- FLOAT Return
SetSampleCount
- UINT SampleCount
Sample Count Type
Number of Samples
InitialiseFIFO
AddSample
- FLOAT Sample
GetMean
- FLOAT Return
GetDeviation
- FLOAT Return
SetSampleCount
- UINT SampleCount
Sample Count Type
Number of Samples
