Component: Switch Slide (Switch)
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Switch
Switch Slide component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Please click here to download the component source project: FC_Comp_Source_Switch_Slide_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Slide_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch. Switch Slide Example
(5V / 11K) * 10K = 4.54545V
ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
SetState
Sets the switch to be on or off.
- BOOL State
The new state of the switch (true=on, false=off)
WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Switch Settings
Connection
Polarity
Debounce
Latching
Component Label
Label Colour
Show Connection Label
Show Pin Value
Style
Type
On Label
Off Label
ReadState
WaitUntilHigh
SetState
- BOOL State
WaitUntilLow
Switch Settings
Connection
Polarity
Debounce
Latching
Component Label
Label Colour
Show Pin Value
Style
Type
On Label
Off Label
ReadState
WaitUntilHigh
SetState
- BOOL State
WaitUntilLow
Switch Settings
Connection
Polarity
Debounce
Latching
Component Label
Label Colour
Show Pin Value
Style
Type
On Label
Off Label
