Component: WLAN (EB069-00-2, RN171) (RN171) (Wireless)
Revision as of 15:25, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.1
Category Wireless
WLAN (EB069-00-2, RN171) component
Wireless LAN component designed to work with the RN171 module from Microchip. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069-00-2 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN-RN171_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN-RN171_Dummy.fcfx
Simple playback example - allows a wav file to be streamed out using PWM. Repeats the playback in a loop.
WAV Playback
Simple recording example - allows a wav file to be recorded from a microphone connected to an ADC input pin. Records for approx 10 seconds.
WAV Record
SendString
Sends the given Text. Appends a CR/LF pair of characters it CrLf is true.
- STRING Text
- BYTE CrLf
SendCommand
Sends the given command and returns the reply status. (See GetReply for return values)
- STRING Command
ReceiveIncoming
Returns the received data string
- STRING Return
CheckForPageRequests
ReadConnectionStatus
Checks the connection status. Returns 0 if not connected, 1 if connected.
SetOutValue
- BYTE index
- STRING value
EnterCommandMode
Attempts to leave data mode and enter command mode
DisableCommandMode
Exits command mode
GetInValue
- BYTE index
Index of the request paramter, starting at zero.
- STRING Return
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 0 if successful.
- STRING SSID
- STRING Key
GetReply
Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT
Initialise the device with the property data. Returns 0 if successful
SendString
- STRING Text
- BYTE CrLf
SendCommand
- STRING Command
ReceiveIncoming
- STRING Return
SetOutValue
- BYTE index
- STRING value
EnterCommandMode
DisableCommandMode
Exits command mode
GetInValue
- BYTE index
- STRING Return
ConnectToSSID
- STRING SSID
- STRING Key
GetReply
SendString
- STRING Text
- BYTE CrLf
SendCommand
- STRING Command
ReceiveIncoming
- STRING Return
SetOutValue
- BYTE index
- STRING value
EnterCommandMode
DisableCommandMode
Exits command mode
GetInValue
- BYTE index
- STRING Return
ConnectToSSID
- STRING SSID
- STRING Key
GetReply
