| Author
Matrix Ltd
| Version
1.1
| Category
Mechatronics
Solenoid Template component
Base component for constructing solenoids. These take a single input pin and move an actuator between two positions depending on the pin state.
Please click here to download the component source project: FC_Comp_Source_solenoid_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_solenoid_base.fcfx
SetTarget
| Choose an extermal object to move along with the solenoid's actuator
- HANDLE
Object
| An object to be moved by the solenoid
TurnOn
| Activate the solenoid
SetState
| Trun the solenoid on or off using a boolean value.
- BOOL
State
| The new state for the solenoid to take.
TurnOff
| De-activate the solenoid
Connection
Pin
| Chip pin to connect the solenoid circuit to. NB) Solenoid cannot be moved unless there is a valid connection.
Moving part
| A panel object to be moved back and forth when the solenoid is activated.
Pivot object
| A position to rotate around when the solenoid type is set to 'Rotate' Not required for linear solenoids.
Type
| The type of motion of the solenoid actuator.
Axis
| For linear solenoids, the axis along which the actuator will move. For rotary solenoids, the axis around which it will rotate.
Distance
| For linear solenoids, the distance between the 'off and 'on' states in model units. For rotary solenoids, the rotation in degrees.
Time (ms)
| The time taken for the solenoid to move between the on and off positions. Used only for the purpose of System Panel animations on screen.
SetTarget
- HANDLE
Object
TurnOn
SetState
- BOOL
State
TurnOff
Connection
Pin
Moving part
Pivot object
Type
Axis
Distance
Time (ms)
SetTarget
- HANDLE
Object
TurnOn
SetState
- BOOL
State
TurnOff
Connection
Pin
Moving part
Pivot object
Type
Axis
Distance
Time (ms)
