Author
Matrix Ltd
Version
1.0
Category
Segment
7Segment (74HC595) component
Seven segment display using 74HC595 serial to parallel shift register. Requires three standard output pins to drive the shift register. Shift registers can be chained together to drive up to six individual 7-segment displays.
Please click here to download the component source project: FC_Comp_Source_74HC595_7SEG_Hex_Driver.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_74HC595_7SEG_Hex_Driver.fcfx
ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Value0
The number value to set the digit to (0...15), 16=Clear
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
Bit field containing the states of the decimal points.
ShowSegments
Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
Which of the digits to change. (0...5)
- BYTE
Segments
The binary segment value to display, 0b1 = Lit, 0b0 = Not Lit
ShowDigit
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Whether to show the decimal point.
Number 7Segs
Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
Show segment name labels overlayed over the component.
Data Pin
Data Pin connection to the first 74HC595 chip
Clock Pin
Clock Pin connection to all the 74HC595 chips
Latch Pin
Latch Pin connection to all the 74HC595 chips
Colors
LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
Color of the plastic casing containing the LEDs.
Label Color
Color for the optional LED segment labels.
ShowDigits
- BYTE
Value0
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
ShowSegments
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Number 7Segs
Display Type
Show Seg Labels
Data Pin
Clock Pin
Latch Pin
Colors
LED Color
Body Color
Label Color
ShowDigits
- BYTE
Value0
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
ShowSegments
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Number 7Segs
Display Type
Show Seg Labels
Data Pin
Clock Pin
Latch Pin
Colors
LED Color
Body Color
Label Color
ShowDigits
- BYTE
Value0
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
ShowSegments
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Number 7Segs
Display Type
Show Seg Labels
Data Pin
Clock Pin
Latch Pin
Colors
LED Color
Body Color
Label Color
ShowDigits
- BYTE
Value0
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Value4
- BYTE
Value5
- BYTE
DecimalPoint
ShowSegments
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Number 7Segs
Display Type
Show Seg Labels
Data Pin
Clock Pin
Latch Pin
Colors
LED Color
Body Color
Label Color
