| Author
Matrix TSL
| Version
1.0
| Category
Graphical Color
Nextion Display component
A simple libray to interface a Nextion display. The elements on the nextion display are built using the Nextion Editor software and uploaded to the display. The component can then interact with the display elements.
Please click here to download the component source project: FC_Comp_Source_API_Display_Nextion.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_Display_Nextion.fcfx
This example looks for button presses with IDs 1 and 2. On a button release event the corresponding LEDs will be toggled.
Nextion Touch Demo
GetTouchID
| Gets the ID of the corresponding touch event. Must be called after calling GetTouchEvent component macro.
- UINT
GetValue
| Gets the value from a specific item
- STRING
Name
- ULONG
SetText
| Sets the text of a specific item
- STRING
Name
- STRING
Text
GetText
| Gets the text of a specific item
- STRING
Name
- STRING
SetFontColour
| Sets the foreground font colour of a specific item
- STRING
Name
- ULONG
Colour
SetPage
| Sets the page of the display allowing multiple configurations
- STRING
Name
| Name of the page e.g. "page0"
SetValue
| Sets the numeric value of a specific item
- STRING
Name
- ULONG
Number
GetTouchEvent
| Collects the next touch event in the queue. Returns 0 for no touch event detected, 1= touch press, 2 = touch release
- BYTE
SetBackgroundColour
| Sets the background colour of a specific item
- STRING
Name
- ULONG
Colour
| Sets up the UART connection to the Nextion display
Communications
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Touch Queue Size
| Number of touch press/release events we can store before running out of memory.
Receive Buffer Size
| Sets the number of byte elements inside the circular buffer.
Timeout
| Time in milliseconds to wait for a reply to a command.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
GetTouchID
- UINT
GetValue
- STRING
Name
- ULONG
SetText
- STRING
Name
- STRING
Text
GetText
- STRING
Name
- STRING
SetFontColour
- STRING
Name
- ULONG
Colour
SetPage
- STRING
Name
SetValue
- STRING
Name
- ULONG
Number
GetTouchEvent
- BYTE
SetBackgroundColour
- STRING
Name
- ULONG
Colour
Communications
Baud Options
TX
RX
Touch Queue Size
Receive Buffer Size
Timeout
Data Source
GetTouchID
- UINT
GetValue
- STRING
Name
- ULONG
SetText
- STRING
Name
- STRING
Text
GetText
- STRING
Name
- STRING
SetFontColour
- STRING
Name
- ULONG
Colour
SetPage
- STRING
Name
SetValue
- STRING
Name
- ULONG
Number
GetTouchEvent
- BYTE
SetBackgroundColour
- STRING
Name
- ULONG
Colour
Communications
Baud Options
TX
RX
Touch Queue Size
Receive Buffer Size
Timeout
Data Source
GetTouchID
- UINT
GetValue
- STRING
Name
- ULONG
SetText
- STRING
Name
- STRING
Text
GetText
- STRING
Name
- STRING
SetFontColour
- STRING
Name
- ULONG
Colour
SetPage
- STRING
Name
SetValue
- STRING
Name
- ULONG
Number
GetTouchEvent
- BYTE
SetBackgroundColour
- STRING
Name
- ULONG
Colour
Communications
Baud Options
TX
RX
Touch Queue Size
Receive Buffer Size
Timeout
Data Source
GetTouchID
- UINT
GetValue
- STRING
Name
- ULONG
SetText
- STRING
Name
- STRING
Text
GetText
- STRING
Name
- STRING
SetFontColour
- STRING
Name
- ULONG
Colour
SetPage
- STRING
Name
SetValue
- STRING
Name
- ULONG
Number
GetTouchEvent
- BYTE
SetBackgroundColour
- STRING
Name
- ULONG
Colour
Communications
Baud Options
TX
RX
Touch Queue Size
Receive Buffer Size
Timeout
Data Source
