| Author
Matrix TSL
| Version
1.0
| Category
Light
Ambient Light component
A small PCB surface mount ambient light sensor with a I2C bus interface. Spectral responsibility is approximately human eye response. Wide range and High resolution. ( 1 - 65535 lx )
Please click here to download the component source project: FC_Comp_Source_AmbientLight_BH1750FVI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AmbientLight_BH1750FVI.fcfx
ContinuousMeasurement
| Powers up and starts the continous measurement mode. Delays in between measurements readings must be provided by the user,
- BYTE
Resolution
| 0=1lx (120ms) / 1=0.5lx (120ms) / 2 = 4lx (16ms)
OneTimeMeasurement
| Powers up and starts a single measurement before returning to power down mode. Waits for the measurement to be ready and returns the value.
- BYTE
Resolution
- UINT
PowerDown
| Power Down the Device
ChangeMeasurementTime
| Adjusts the measurement result to counteract influence of the optical window.
- BYTE
Sensitvity
| Range: 31-254 / Default: 69
ReadMeasurement
| Reads data from the Light Sensor as a 16-bit value.
- UINT
ResetMeasurement
| Resets the device measurement register, Must be in the powered up state to do this.
| Stes up the I2C bus and initialises the termperature sensor ready for use.
I2C Properties
Slave Address
| Channel selection
SDA
SCL
DVI Pin
| Pin used to reset the device.
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
Simulate Comms
| Allows the simulation data to come from the panel GUI or relayed via an injector component.
- BYTE
Resolution
OneTimeMeasurement
- BYTE
Resolution
- UINT
PowerDown
- BYTE
Sensitvity
ReadMeasurement
- UINT
ResetMeasurement
I2C Properties
Slave Address
| Channel selection
SDA
SCL
DVI Pin
Baud Select
Stop Delay
Simulate Comms
- BYTE
Resolution
OneTimeMeasurement
- BYTE
Resolution
- UINT
PowerDown
- BYTE
Sensitvity
ReadMeasurement
- UINT
ResetMeasurement
I2C Properties
Slave Address
| Channel selection
SDA
SCL
DVI Pin
Baud Select
Stop Delay
Simulate Comms
- BYTE
Resolution
OneTimeMeasurement
- BYTE
Resolution
- UINT
PowerDown
- BYTE
Sensitvity
ReadMeasurement
- UINT
ResetMeasurement
I2C Properties
Slave Address
| Channel selection
SDA
SCL
DVI Pin
Baud Select
Stop Delay
Simulate Comms
- BYTE
Resolution
OneTimeMeasurement
- BYTE
Resolution
- UINT
PowerDown
- BYTE
Sensitvity
ReadMeasurement
- UINT
ResetMeasurement
I2C Properties
Slave Address
| Channel selection
SDA
SCL
DVI Pin
Baud Select
Stop Delay
Simulate Comms
