Component: Bluetooth (RN4677) (RN4677) (Wireless)
Revision as of 09:54, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.4
Category Wireless
Bluetooth (RN4677) component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_RN4677.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_RN4677.fcfx
ReceiveByte
Receives a single data byte from the Bluetooth module. 0-255 - Valid Data / 256 signifies no data available.
- UINT Timeout
Amount of time to wait in milliseconds 0=Wait forever
SendString
Sends a string to the Bluetooth module.
- STRING Text
- BYTE SendCR
LeaveCommandMode
Leaves command mode allowing data to be passed back and forth,
ConnectToMAC
Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful.
- STRING MACAddress
MAC Address of the Bluetooth Device we wish to connect to
- BOOL Return
SendCommand
Sends a command string to the Bluetooth module. 0 = Command sent ok, 255 = No Reply
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
0=Do not touch the reply, 1=Wait for reply and remove from buffer
ReadString
Copies the incoming data from the data string array to a local string variable.
- BYTE NumBytes
Maximum number of bytes to try and read
- STRING Return
SendByte
Sends a single data byte out to the Bluetooth module.
- BYTE Data
EnterCommandMode
Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK
- BOOL Return
WaitForStringValue
Allows us to wait and check for an incoming value. Returns 1 if the string value is found otherwise returns 0.
- STRING Value
String value to look for
- UINT Timeout
Length of time to wait in milliseconds
- BOOL Return
GetMACAddress
Gets the local Bluetooth device MAC address.
- STRING Return
Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply.
Bluetooth Settings
Init Details
Allows the Bluetooth device name and key to be automatically assigned on initialise.
Device Name
Sets the friendly name of the Bluetooth device.
Pair Key
Discoverable
Is the Bluetooth module discoverable by default?
Reply Timeout
Specifies the amount of time to wait for incoming data before timing out in milliseconds. Default 2000 = 2 seconds.
RX Buffer Size
Amount of RAM memory to dedicate to receiving responses and incoming data from the BT module. Default 40
Baud Options
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
ReceiveByte
- UINT Timeout
SendString
- STRING Text
- BYTE SendCR
LeaveCommandMode
ConnectToMAC
- STRING MACAddress
- BOOL Return
SendCommand
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
ReadString
- BYTE NumBytes
- STRING Return
SendByte
- BYTE Data
EnterCommandMode
- BOOL Return
WaitForStringValue
- STRING Value
- UINT Timeout
- BOOL Return
GetMACAddress
- STRING Return
Bluetooth Settings
Init Details
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
ReceiveByte
- UINT Timeout
SendString
- STRING Text
- BYTE SendCR
LeaveCommandMode
ConnectToMAC
- STRING MACAddress
- BOOL Return
SendCommand
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
ReadString
- BYTE NumBytes
- STRING Return
SendByte
- BYTE Data
EnterCommandMode
- BOOL Return
WaitForStringValue
- STRING Value
- UINT Timeout
- BOOL Return
GetMACAddress
- STRING Return
Bluetooth Settings
Init Details
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
ReceiveByte
- UINT Timeout
SendString
- STRING Text
- BYTE SendCR
LeaveCommandMode
ConnectToMAC
- STRING MACAddress
- BOOL Return
SendCommand
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
ReadString
- BYTE NumBytes
- STRING Return
SendByte
- BYTE Data
EnterCommandMode
- BOOL Return
WaitForStringValue
- STRING Value
- UINT Timeout
- BOOL Return
GetMACAddress
- STRING Return
Bluetooth Settings
Init Details
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
ReceiveByte
- UINT Timeout
SendString
- STRING Text
- BYTE SendCR
LeaveCommandMode
ConnectToMAC
- STRING MACAddress
- BOOL Return
SendCommand
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
ReadString
- BYTE NumBytes
- STRING Return
SendByte
- BYTE Data
EnterCommandMode
- BOOL Return
WaitForStringValue
- STRING Value
- UINT Timeout
- BOOL Return
GetMACAddress
- STRING Return
Bluetooth Settings
Init Details
Device Name
Pair Key
Discoverable
Reply Timeout
RX Buffer Size
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Use Flow Control
Reset Pin
Simulate Comms
Console Columns
Data Source
