Component: DAC (AD5662) (Analog Output)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Category Analog Output
DAC (AD5662) component
16-bit external DAC connected to the microcontroller using SPI.
Please click here to download the component source project: FC_Comp_Source_DAC_AD5662.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_AD5662.fcfx
Overview
The AD5662 is a 3V/5V general purpose SPI compatible, high-resolution digital to analog converter (DAC), capable of generating a rail-to-rail voltage output.
With 16-Bit resolution, the AD5662 is capable of finely tuning the voltage output across 65,536 steps, with an individual step voltage of 5/65536 = 0.0000763 volts DC.
The AD5662 requires an external reference voltage to set the output range of the DAC.
Pin reference from the datasheet:
Circuit Diagram
This example reads a potentiometer that is connected across the supply voltage. The output from the DAC should mimic the voltage that's across ADC pin & GND.
AD5662_Demo
OutputDAC
Outputs a value to the DAC,
- UINT Output
Range: 0-65535 / 0=0V / 65535=VCC
Initialise the SPI bus ready for communications,
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
OutputDAC
- UINT Output
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
OutputDAC
- UINT Output
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
OutputDAC
- UINT Output
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
OutputDAC
- UINT Output
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
