| Author | MatrixTSL |
| Category | Comms: System |
DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from  VCC and GND to +9.5V - +25.5V and GND.  The master component can addess up to 64 individual slaves & up to 16 groups.
Please click here to download the component source project: FC_Comp_Source_DALI_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Master.fcfx
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level.
 DALI Master Example1
For a DALI Slave example see: Component: DALI Slave (Comms: System)
|   | ReceiveBackwardFrame |
| Attempts to receive an 8-bit reply  0 indicates timeout or no reply |
|  - BYTE | Return |
|   | TransmitForwardFrame |
| Send out a 16-bit frame consisting of the 8-bit address and data bytes. After sending the controller will attempt to receive  If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0. |
|  - BYTE | Address |
| Address byte |
|  - BYTE | Data |
| Data Byte |
|  - BYTE | Return |
|   | TransmitIndividualForwardFrame |
| Sends out an individual frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0. |
|  - BYTE | Address |
| Individual Address 0-63 |
|  - BYTE | Type |
| 0 = Data, 1 = Command |
|  - BYTE | Data |
|  - BYTE | Return |
|   | TransmitGroupForwardFrame |
| Sends out a group frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0. |
|  - BYTE | Address |
| Group Address 0-15 |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|   | Initialise |
| Configures the UART serial interface. |
|  - VOID | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | Simulation |
|   | API |
|  - BYTE | Return |
|  - BYTE | Address |
| Address byte |
|  - BYTE | Data |
| Data Byte |
|  - BYTE | Return |
|  - BYTE | Address |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|  - BYTE | Address |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | Simulation |
|   | API |
|  - BYTE | Return |
|  - BYTE | Address |
| Address byte |
|  - BYTE | Data |
| Data Byte |
|  - BYTE | Return |
|  - BYTE | Address |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|  - BYTE | Address |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | Simulation |
|   | API |
|  - BYTE | Return |
|  - BYTE | Address |
| Address byte |
|  - BYTE | Data |
| Data Byte |
|  - BYTE | Return |
|  - BYTE | Address |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|  - BYTE | Address |
|  - BYTE | Type |
|  - BYTE | Data |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | Simulation |
|   | API |
