Component: Digital Multimeter (HY3131) (Sensors)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Sensors
Digital Multimeter component
A component allowing access to the digital multimeter IC HY3131.
Please click here to download the component source project: FC_Comp_Source_DMM_HY3131.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DMM_HY3131.fcfx
ReadRegister
A simple example showing a generic way to read a register using I2C.
- BYTE Address
WriteRegister
A simple example showing a generic way to write a register using I2C.
- BYTE Address
- BYTE Data
SPI Properties
SPI Channel selector
MOSI
MISO
CLK
Use Auto CS
Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
CS / SS
Options
Mode
Configures the mode of the SPI component. Currently only Master mode is supported.
Prescale
Prescale option selector
Clock Phase
Clock Polarity
Sample Point
Data bit read sample point
Simulate Comms
Scale
Select Scale
ReadRegister
- BYTE Address
WriteRegister
- BYTE Address
- BYTE Data
SPI Properties
MOSI
MISO
CLK
Use Auto CS
CS / SS
Options
Mode
Prescale
Clock Phase
Clock Polarity
Sample Point
Simulate Comms
Scale
Select Scale
ReadRegister
- BYTE Address
WriteRegister
- BYTE Address
- BYTE Data
SPI Properties
MOSI
MISO
CLK
Use Auto CS
CS / SS
Options
Mode
Prescale
Clock Phase
Clock Polarity
Sample Point
Simulate Comms
Scale
Select Scale
ReadRegister
- BYTE Address
WriteRegister
- BYTE Address
- BYTE Data
SPI Properties
MOSI
MISO
CLK
Use Auto CS
CS / SS
Options
Mode
Prescale
Clock Phase
Clock Polarity
Sample Point
Simulate Comms
Scale
Select Scale
