| Author
Matrix Ltd
| Version
1.2
| Category
DSP Operators
Fast Fourier Transform (FFT) component
Provides a way of converting a buffer full of time domain data into frequency domain data. The output of the FFT is a set of frequency bins which correspond to the frequencies present in the signal. The number of frequency bins is equal to half the input buffer size with each bin being responsible for a portion of the frequency up to 1/2 the nyquist.
Please click here to download the component source project: FC_Comp_Source_DSP_FFT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_FFT.fcfx
Example takes two adjustable frequency sine wave inputs and combines them and then passes the collection of 256 samples to the FFT function which produces 128 individual frequency banks which are then plotted from left (lowest frequency) to right (highest frequency) using an XY chart component.
FFT Example
Frequency output for a set of data
Frequency banks can be worked out by using the sample frequency and buffer size. The number of frequency banks is equal to the number of samples divided by 2 minus 1. We subtract the one because bank 0 is always empty and so can be discounted.
FrequencyBanks = (SampleCount / 2) - 1
The frequency ranges present inside a bank can be worked out as follows.
FreqMin = ((SampleRate / 2) / (SampleCount / 2)) * Bank
FreqMax = ((SampleRate / 2) / (SampleCount / 2)) * (Bank + 1)
For example if we sample at 10KHz and collect 256 samples then frequency bank 10 would represent any frequencies in the range of 390.6Hz to 429.7Hz.
Here is a spreadsheet document that will calculate the frequencies present in each bank. The highlighted green fields are editable and will update the rest of the values.
File:FFT Frequency Bank Calculator.xls
ReadFrequencyBank
| Reads the value from one of the frequency banks after the FFT conversion has been performed. Valid frequency banks range from 1 to the allocated buffer size / 2 assuming the buffers are sized to be equal to a power of 2.
- UINT
BankIdx
- UINT
FFT
| Performs the data conversion from time based data to frequency based data. Takes a full buffer input and converts it into real and imaginary frequency data ready for you to read the individual frequency bins.
QueueData
| Takes a single value from the buffer input and stores it, once there are enough values queued up it returns a 1.
- BOOL
ProcessWhenFull
| 0 = Do Nothing when Buffer is full, 1 = Auto call FFT macro when Buffer is full
- BOOL
Connect To
| DSP component with output buffer to collect our data from.
Buffer Size
| Number of individual elements the buffer can store, must be a power of 2, default 256.
Buffer Type
| Sets the buffer data type.
Filter Input Data
| Applies a hamming window filter to the time domain sample data to provide better frequency detection.
Calculations
Sample Rate
| Sample rate used to perform simple calculations like nyquist and bin size.
Nyquist Frequency
| The maximum frequency that can theoretically be detected by the FFT component assuming the sample rate is setup correctly.
Frequency Bin Count
| The number of frequency bins that the component will provide.
Frequency Bin Size (Hz)
| The frequency range covered by each frequency bin.
ReadFrequencyBank
- UINT
BankIdx
- UINT
FFT
QueueData
- BOOL
ProcessWhenFull
- BOOL
Connect To
Buffer Size
Buffer Type
Filter Input Data
Calculations
Sample Rate
Nyquist Frequency
Frequency Bin Count
ReadFrequencyBank
- UINT
BankIdx
- UINT
FFT
QueueData
- BOOL
ProcessWhenFull
- BOOL
Connect To
Buffer Size
Buffer Type
Filter Input Data
Calculations
Sample Rate
Nyquist Frequency
Frequency Bin Count
ReadFrequencyBank
- UINT
BankIdx
- UINT
FFT
QueueData
- BOOL
ProcessWhenFull
- BOOL
Connect To
Buffer Size
Buffer Type
Filter Input Data
Calculations
Sample Rate
Nyquist Frequency
Frequency Bin Count
