| Author
Matrix
| Version
1.1
| Category
Dashboard lamp component
Indicator with bezel and label, particularly suitable for viewing on the dashboard. Indicator on/off colors, bezel color and label all editable via properties.
Please click here to download the component source project: FC_Comp_Source_Dashboard_Indicator.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Indicator.fcfx
LED Resistor Calculator Tool
Pin
| Chip pin to connect the LED to.
Polarity
| Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color
On Color
| The color of the indicator when it is turned on.
Off Color
| The color of the indicator when it is turned off.
Bezel Color
| Color of the bezel.
Label Color
| Color of the label text.
Text
| Text to show as the component label.
Font
| Font for the label text.
Pin
Polarity
On Color
Off Color
Bezel Color
| Color of the bezel.
Label Color
Text
Font
Pin
Polarity
On Color
Off Color
Bezel Color
| Color of the bezel.
Label Color
Text
Font
Pin
Polarity
On Color
Off Color
Bezel Color
| Color of the bezel.
Label Color
Text
Font
