Component: Device Helper (Matrix Tools)
Revision as of 09:55, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Matrix Tools
Device Helper component
A purely cosmetic component for viewing the details specific to your current selected target microcontroller. Lists stats like ADC resolution, ADC channels, UARTs, SPI, PWM, RAM, ROM etc
Please click here to download the component source project: FC_Comp_Source_Device_Helper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Device_Helper.fcfx
By simply adding the device helper component to your project and selecting it on the panel you can see all the following statistics regarding your current selected microcontroller in the properties window.
Device
Pin Count
Max Clock Speed
Maximum frequency the device can operate.
Master Divider
Number of clock cycles per single device instruction.
Max MIPs
Million Instructions Per Second (MIPS) Number of complete instruction cycles per second based on the max clock speed and instructions per clock divided by 1 million. Note that some instructions such as decisions can take multiple instructions to complete.
Memory
ROM Size
Number of bytes available for ROM storage. ROM - Read Only Memory - Contains the Flowcode program as well as other constants such as strings
RAM Size
Number of bytes available for RAM storage. RAM - Random Access Memory - Contains the Flowcode variables as well as the operational stack
EEPROM Size
Number of bytes available for EEPROM storage. EEPROM - Electrically Erasable Programmable Read Only Memory - Contains user data that can persist when the power is removed
Analogue
ADC Max Bits
Maximum number of bits used for an ADC conversion which dictates the maximum reading the ADC can generate. 8 bits = 0 - 255 10 bits = 0 - 1023 12 bits = 0 - 4095
ADC Pins
Number of pins capable of reading an analogue input.
DAC Max Bits
Maximum number of bits used for an DAC conversion which dictates the output resolution of the DAC. 5 bits = 0 - 31 8 bits = 0 - 255 10 bits = 0 - 1023
DAC Pins
Number of pins capable of outputting an analogue voltage.
Digital / Peripheral
Digital Pins
Number of pins capable of reading a digital input and/or writing a digital output.
CAN Count
Controller Area Network (CAN) Used for fixed system architecture in noisy environments e.g. Cars and Automotive
I2C Count
Inter-Integrated Circuit (I2C) Used for on board communications e.g. Sensors, Memory
I2C Modes
H-Bridge Count
PWM Count
Pulse Width Modulation Output (PWM) Useful for analogue style outputs.
SPI Count
Serial Peripheral Interface (SPI) Used for high speed on board communications e.g. Sensors, Memory
UART Count
Universal Asynchronous Receiver Transmitter (UART) Used for on board and off board communications e.g. RS232, Bluetooth, GPS, GSM
USB Count
Universal Serial Bus (USB) Used for interconnective communications with high end equipment such as PCs.
Device
Pin Count
Max Clock Speed
Master Divider
Max MIPs
Memory
ROM Size
RAM Size
EEPROM Size
Analogue
ADC Max Bits
ADC Pins
DAC Max Bits
DAC Pins
Digital Pins
CAN Count
I2C Count
I2C Modes
H-Bridge Count
PWM Count
SPI Count
UART Count
USB Count
Device
Pin Count
Max Clock Speed
Master Divider
Max MIPs
Memory
ROM Size
RAM Size
EEPROM Size
Analogue
ADC Max Bits
ADC Pins
DAC Max Bits
DAC Pins
Digital Pins
CAN Count
I2C Count
I2C Modes
H-Bridge Count
PWM Count
SPI Count
UART Count
USB Count
Device
Pin Count
Max Clock Speed
Master Divider
Max MIPs
Memory
ROM Size
RAM Size
EEPROM Size
Analogue
ADC Max Bits
ADC Pins
DAC Max Bits
DAC Pins
Digital Pins
CAN Count
I2C Count
I2C Modes
H-Bridge Count
PWM Count
SPI Count
UART Count
USB Count
