Component: Potentiometer (EBM002) (EBM Modules)
| Version | 1.1 |
| Category | EBM Modules |
Potentiometer component
This board consists of a standard shaft rotary potentiometer that provides a linear voltage output ranging between the microcontroller power rails. This can be connected to an Analogue to Digital input of the microcontroller in order to provide a control value.
Please click here to download the component source project: FC_Comp_Source_EBM002v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM002v1.fcfx
This example simply reads the value from the potentiometer sensor component and outputs the value to an LCD as a number in the range 0-255.
The ADC bit depth can be increased to 10 or 12 bit depending on your device by changing the Mode parameter to 1 in the ReadPotentiometer component macro.
| ReadPotentiometer | |
| Macro to read the potentiometer Mode = 0 will return a byte Mode = 1 will return an int | |
| Mode | |
| 0 = return BYTE, 1 = return INT | |
| Mode | |
| Mode | |
| Mode | |
