Component: Actuators (BL0127) (E-blocks 2)
Revision as of 09:56, 27 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Actuators component
The Actuators board allows for investigation into several different motor types. Included on the board is a DC motor with both analogue and digital feedback, a servo motor and a stepper motor plus the circuitry to drive the motors.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Sample program using the EBM020 - Infrared sensor.
Transmits a signal and determines distance from reflected value
EBM020 Example
DCMotor_DC_Feedback
DCMotor_Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
- UINT Duty
Sets the motor power for PWM or H-Bridge outputs
Servo_MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE Channel
The channel to assign the new position. Range: 0-7
- BYTE Position
Target position to move towards. Range: 0-255
DCMotor_Enable
Enables the motor output
Stepper_DisableMotor
Turn off the motor. It will no longer respond to any other macros.
Stepper_IncrementStep
Move the motor forward by one step.
Servo_EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE Channel
The channel to set the position for. First channel is zero.
Servo_SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
- BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Servo_MoveToPositionInt
- BYTE Channel
- UINT Position
Target position to move towards. Range: 0-65535
DCMotor_Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Servo_IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
Servo_IsServoAutoMoving
Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
- BYTE Channel
Servo Motor Output Range: 0-7
Stepper_DecrementStep
Move the motor backwards by one step.
Servo_SetPositionInt
Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
- BYTE Channel
- UINT Position
Position to jump to. Range: 0-65535
Servo_SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE Channel
- BYTE Trim
Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
DCMotor_Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Servo_Initialise
Sets up the servo motor interrupts
DCMotor_Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
- UINT Duty
Servo_SetAutoMoveSpeedInt
- UINT Speed
DCMotor_Disable
Disable the motor output
Stepper_EnableMotor
Turn on the motor. This must be done before it will respond to any other macros.
Servo_SetPosition
- BYTE Channel
- BYTE Position
Position to jump to. Range: 0-255
DCMotor_DC_FeedbackSim
Servo_AutoMoveToPosition
Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
- BYTE Channel
- BYTE Position
Position to automatically move to. Range: 0-255
Servo_AutoMoveToPositionInt
Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
- BYTE Channel
- UINT Position
Position to automatically move to. Range: 0-65535
Servo_DisableServo
Disables a servo channel effectivly disabling the motor.
- BYTE Channel
Connection Type
DC Feedback type
Select if the feedback is a digital or analogue value. Note, if using an Arduino shield and port D is selected, then only digital type will be available.
Port
Port C is not available on the Arduino shield, If port C is slected, it will default to port B.
Servo
Trim
Pulse Width
Minimum (us)
Shortest pulse width that will be used in microseconds.
Maximum (us)
Longest pulse width used for the PWM signals in microseconds..
Period Multiplier
Number of instructions for 1 / 256th of the positional accuracy. This sets the default movement speed to maintain legacy move speeds. Also sets the multiplication factor to convert from a byte 0-255 to a clocked position value.
DCMotor_DC_Feedback
DCMotor_Reverse
- UINT Duty
- BYTE Channel
- BYTE Position
DCMotor_Enable
Servo_EnableServo
- BYTE Channel
- BYTE Speed
- BYTE Channel
- UINT Position
DCMotor_Coast
Servo_IsAutoMoving
- BYTE Channel
- BYTE Channel
- UINT Position
Servo_SetTrim
- BYTE Channel
- BYTE Trim
DCMotor_Break
Servo_Initialise
DCMotor_Forwards
- UINT Duty
- UINT Speed
DCMotor_Disable
Stepper_EnableMotor
Servo_SetPosition
- BYTE Channel
- BYTE Position
- BYTE Channel
- BYTE Position
- BYTE Channel
- UINT Position
Servo_DisableServo
- BYTE Channel
Connection Type
DC Feedback type
Port
Servo
Trim
Pulse Width
Minimum (us)
Maximum (us)
Period Multiplier
DCMotor_DC_Feedback
DCMotor_Reverse
- UINT Duty
- BYTE Channel
- BYTE Position
DCMotor_Enable
Servo_EnableServo
- BYTE Channel
- BYTE Speed
- BYTE Channel
- UINT Position
DCMotor_Coast
Servo_IsAutoMoving
- BYTE Channel
- BYTE Channel
- UINT Position
Servo_SetTrim
- BYTE Channel
- BYTE Trim
DCMotor_Break
Servo_Initialise
DCMotor_Forwards
- UINT Duty
- UINT Speed
DCMotor_Disable
Stepper_EnableMotor
Servo_SetPosition
- BYTE Channel
- BYTE Position
- BYTE Channel
- BYTE Position
- BYTE Channel
- UINT Position
Servo_DisableServo
- BYTE Channel
Connection Type
DC Feedback type
Port
Servo
Trim
Pulse Width
Minimum (us)
Maximum (us)
Period Multiplier
DCMotor_DC_Feedback
DCMotor_Reverse
- UINT Duty
- BYTE Channel
- BYTE Position
DCMotor_Enable
Servo_EnableServo
- BYTE Channel
- BYTE Speed
- BYTE Channel
- UINT Position
DCMotor_Coast
Servo_IsAutoMoving
- BYTE Channel
- BYTE Channel
- UINT Position
Servo_SetTrim
- BYTE Channel
- BYTE Trim
DCMotor_Break
Servo_Initialise
DCMotor_Forwards
- UINT Duty
- UINT Speed
DCMotor_Disable
Stepper_EnableMotor
Servo_SetPosition
- BYTE Channel
- BYTE Position
- BYTE Channel
- BYTE Position
- BYTE Channel
- UINT Position
Servo_DisableServo
- BYTE Channel
Connection Type
DC Feedback type
Port
Servo
Trim
Pulse Width
Minimum (us)
Maximum (us)
Period Multiplier
