Component: Electrical Machines (AllCode)
| Version | 2.0 |
| Category | AllCode |
Electrical Machines component
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
Please click here to download the component source project: FC_Comp_Source_EM_Functions.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_EM_Functions.fcsx
| GetLogDataReady | |
| Checks to see if the logging is complete and ready to read. | |
| GetRPM | |
| Reads the speed in RPM | |
| GetWeight | |
| Reads the voltage of a single channel | |
| Scale | |
| Range: 0-1 - 0=Weight, 1=Torque | |
| SetControlKP | |
| Value | |
| SetControlSetpoint | |
| Value | |
| GetAPIVersion | |
| Reads the API firmware version | |
| GetLogData | |
| Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK | |
| Buffer | |
| Buffer to store the incoming log data | |
| GetSafetySwitch | |
| Reads the safety switch | |
| SetControlKI | |
| Value | |
| ZeroLoadCell | |
| SetControlMaxDrivePercentage | |
| Value | |
| Range 0.0-1.0 | |
| SetMotorType | |
| MotorType | |
| 0=DC, 1=1 Phase, 2=3 Phase | |
| SetLoadCellCalibration | |
| Value | |
| GetVoltage | |
| Channel | |
| Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT | |
| GetControlFeedback | |
| SetControlKD | |
| Value | |
| SetCapacitorBank | |
| Cap | |
| GetCommsOK | |
| Checks if comms are ok and stable | |
| GetLogStartAngle | |
| Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data. | |
| SetVoltage | |
| Sets the DC Voltage from 0 to 24V | |
| Voltage | |
| Index | |
| Get3PhaseMode | |
| Checks to see if the brushless mode is enabled | |
| GetAbsPosition | |
| Reads the absolute position of the encoder | |
| SetFan | |
| |Sets the speed of the FAN from 0 (MIN) to 3000 (MAX) | |
| Speed | |
| SetMotorDirection | |
| MotorDirection | |
| 0=FW, 1=BW | |
| GetMotorDirection | |
| Reads the motor direction | |
| SetThreePhaseDriveMode | |
| Mode | |
| 0=Simple, 1=Accurate | |
| GetCurrent | |
| Reads the current of a single channel | |
| Channel | |
| Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver | |
| SetFrequency | |
| Frequency | |
| Frequency of sine wave in Hz | |
| SetDynoLoad | |
| Load | |
| GetControlOutputs | |
| Data | |
| SetActive | |
| Active | |
| 0=Off, 1=On | |
| SetDriveMode | |
| Mode | |
| 0=PWM, 1=On/Off/Float | |
| SetTCPProps | |
| Sets the TCP IP address and Port | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetAbsPosition | |
| Resets the absolute motor position to 0 | |
| Returns 1 if the connection is ok and communications have been established | |
| MotorType | |
| 0=DC, 1=1Phase, 2=3Phase, 3=AngleControl | |
| GetLogDataReady | |
| GetRPM | |
| GetWeight | |
| Scale | |
| SetControlKP | |
| Value | |
| Value | |
| GetAPIVersion | |
| GetLogData | |
| Buffer | |
| GetSafetySwitch | |
| SetControlKI | |
| Value | |
| ZeroLoadCell | |
| Value | |
| Range 0.0-1.0 | |
| SetMotorType | |
| MotorType | |
| Value | |
| GetVoltage | |
| Channel | |
| SetControlKD | |
| Value | |
| Cap | |
| GetCommsOK | |
| SetVoltage | |
| Voltage | |
| Index | |
| Get3PhaseMode | |
| GetAbsPosition | |
| SetFan | |
| Speed | |
| MotorDirection | |
| 0=FW, 1=BW | |
| Mode | |
| GetCurrent | |
| Channel | |
| SetFrequency | |
| Frequency | |
| SetDynoLoad | |
| Load | |
| Data | |
| SetActive | |
| Active | |
| 0=Off, 1=On | |
| SetDriveMode | |
| Mode | |
| SetTCPProps | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetAbsPosition | |
| MotorType | |
| GetLogDataReady | |
| GetRPM | |
| GetWeight | |
| Scale | |
| SetControlKP | |
| Value | |
| Value | |
| GetAPIVersion | |
| GetLogData | |
| Buffer | |
| GetSafetySwitch | |
| SetControlKI | |
| Value | |
| ZeroLoadCell | |
| Value | |
| Range 0.0-1.0 | |
| SetMotorType | |
| MotorType | |
| Value | |
| GetVoltage | |
| Channel | |
| SetControlKD | |
| Value | |
| Cap | |
| GetCommsOK | |
| SetVoltage | |
| Voltage | |
| Index | |
| Get3PhaseMode | |
| GetAbsPosition | |
| SetFan | |
| Speed | |
| MotorDirection | |
| 0=FW, 1=BW | |
| Mode | |
| GetCurrent | |
| Channel | |
| SetFrequency | |
| Frequency | |
| SetDynoLoad | |
| Load | |
| Data | |
| SetActive | |
| Active | |
| 0=Off, 1=On | |
| SetDriveMode | |
| Mode | |
| SetTCPProps | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetAbsPosition | |
| MotorType | |
| GetLogDataReady | |
| GetRPM | |
| GetWeight | |
| Scale | |
| SetControlKP | |
| Value | |
| Value | |
| GetAPIVersion | |
| GetLogData | |
| Buffer | |
| GetSafetySwitch | |
| SetControlKI | |
| Value | |
| ZeroLoadCell | |
| Value | |
| Range 0.0-1.0 | |
| SetMotorType | |
| MotorType | |
| Value | |
| GetVoltage | |
| Channel | |
| SetControlKD | |
| Value | |
| Cap | |
| GetCommsOK | |
| SetVoltage | |
| Voltage | |
| Index | |
| Get3PhaseMode | |
| GetAbsPosition | |
| SetFan | |
| Speed | |
| MotorDirection | |
| 0=FW, 1=BW | |
| Mode | |
| GetCurrent | |
| Channel | |
| SetFrequency | |
| Frequency | |
| SetDynoLoad | |
| Load | |
| Data | |
| SetActive | |
| Active | |
| 0=Off, 1=On | |
| SetDriveMode | |
| Mode | |
| SetTCPProps | |
| IP0 | |
| IP1 | |
| IP2 | |
| IP3 | |
| Port | |
| SetAbsPosition | |
| MotorType | |
