Component: File (RPI) (File)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.7 |
Category | File |
File (RPI) component
File component allowing access to read and write files on the Raspberry Pi file system.
Please click here to download the component source project: FC_Comp_Source_File_RPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_RPI.fcfx
MoveToNextFileSector |
Not currently implemented on the RPI | |
ForceNextSector |
Return |
WriteByteToBuffer |
Address |
Data |
Return |
AppendByteToFile |
Data |
Return |
CloseFile |
Return |
ReadByteFromIndex |
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer. | |
Address |
Return |
DeleteFile |
Filename |
Return |
CreateFile |
Filename |
Return |
OpenFolder |
Folder_Name |
Return |
ReadFileLength |
Return |
WriteFileSector |
Return |
SetFileIndex |
File_Index |
Range: 0 to 4 | |
Return |
AppendStringToFile |
Data_String |
Return |
ReadFileSize |
Reads the entire size of the current file in bytes. | |
Return |
Properties |
Root Folder |
Root location on the RPI where the files will be stored | |
File Count |
Number of simultaneous files we want to access. | |
Simulation |
Sim Root Folder |
ForceNextSector |
Return |
WriteByteToBuffer |
Address |
Data |
Return |
AppendByteToFile |
Data |
Return |
CloseFile |
Return |
ReadByteFromIndex |
Address |
Return |
DeleteFile |
Filename |
Return |
CreateFile |
Filename |
Return |
OpenFolder |
Folder_Name |
Return |
ReadFileLength |
Return |
WriteFileSector |
Return |
SetFileIndex |
File_Index |
Range: 0 to 4 | |
Return |
Data_String |
Return |
ReadFileSize |
Return |
Properties |
Root Folder |
File Count |
Simulation |
Sim Root Folder |
ForceNextSector |
Return |
WriteByteToBuffer |
Address |
Data |
Return |
AppendByteToFile |
Data |
Return |
CloseFile |
Return |
ReadByteFromIndex |
Address |
Return |
DeleteFile |
Filename |
Return |
CreateFile |
Filename |
Return |
OpenFolder |
Folder_Name |
Return |
ReadFileLength |
Return |
WriteFileSector |
Return |
SetFileIndex |
File_Index |
Range: 0 to 4 | |
Return |
Data_String |
Return |
ReadFileSize |
Return |
Properties |
Root Folder |
File Count |
Simulation |
Sim Root Folder |
ForceNextSector |
Return |
WriteByteToBuffer |
Address |
Data |
Return |
AppendByteToFile |
Data |
Return |
CloseFile |
Return |
ReadByteFromIndex |
Address |
Return |
DeleteFile |
Filename |
Return |
CreateFile |
Filename |
Return |
OpenFolder |
Folder_Name |
Return |
ReadFileLength |
Return |
WriteFileSector |
Return |
SetFileIndex |
File_Index |
Range: 0 to 4 | |
Return |
Data_String |
Return |
ReadFileSize |
Return |
Properties |
Root Folder |
File Count |
Simulation |
Sim Root Folder |
