| Author
Matrix TSL
| Version
1.0
| Category
Light
Colour Sensor (Grove 101020341) component
Based on the color sensor TCS34725FN with digital output I2C. Based on the 8*2 array of filtered photodiodes and 16-bits analog-to-digital converters, you can gain the color chromaticity of ambient light or the color of objects. Of the 16 photodiodes, 4 have red filters, 4 have green filters, 4 have blue filters and 4 have no filter(clear). With the synchronization input pin, external pulsed light source can provides precise synchronous conversion control.
Please click here to download the component source project: FC_Comp_Source_I2C_Colour_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Colour_Sensor.fcfx
ControlInterrupt
| Enables or Disables the Interrupt pin to fire when the light levels are inside the interrupt limits.
- BYTE
Enable
| Range: 0 to 1 - 0=Interrupt Off / 1=Interrupt On
- UINT
LowLevel
- UINT
HighLevel
SetGain
| Controls the gain. 0x00 = 1X 0x01 = 4X 0x02 = 16X 0x03 = 60X
- BYTE
Setting
| Range: 0 to 3
ClearInterrupt
| Clears the interrupt flag allowing the device to interrupt again.
CalculateTemp
| Uses the RGB values stored in RAM from the last Sample to calculate the colour temperature in degrees Kelvin.
- UINT
EnableSensor
| Powers up the device ready for taking colour readings.
CalculateLux
| Uses the RGB values stored in RAM from the last Sample to calculate the luminance in lux.
- UINT
SampleSensor
| Reads the raw colour channels from the sensor and stores the readings into RAM to be collected by the ReadDataChannel macro.
ReadDataChannel
| Returns the value of the selected colour channel from the last sample. The Red, Green and Blue channels have a colour filter to remove light of other colours. The Clear channel has no filter allowing the ambient light level to be easily collected.
- BYTE
ColourChannel
| Range: 0 to 3 - 0=Red, 1=Green, 2=Blue, 3=Clear
- UINT
DisableSensor
| Powers down the device to save power.
SetIntegrationTime
| Controls the integration time. 0 = 700mS / 1 = 154mS / 2 = 101mS / 3 = 50mS / 4 = 24mS / 5 = 2.4mS
- BYTE
Setting
| Range: 0 to 5
| Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor.
Sensor Settings
Integration Time
| Length of time period used to sample the sensor frequency (longer is more accurate)
Gain
I2C Settings
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Simulation Type
| Selects the simulation type for the component. Component GUI - Interacts with the panel to sense the colour of a object in close proximity to the sensor. I2C Injector - Performs the I2C commands allowing you to connect an injector component or view and debug the I2C communications.
ControlInterrupt
- BYTE
Enable
- UINT
LowLevel
- UINT
HighLevel
SetGain
- BYTE
Setting
| Range: 0 to 3
ClearInterrupt
CalculateTemp
- UINT
EnableSensor
CalculateLux
- UINT
SampleSensor
ReadDataChannel
- BYTE
ColourChannel
- UINT
DisableSensor
SetIntegrationTime
- BYTE
Setting
| Range: 0 to 5
Sensor Settings
Integration Time
Gain
I2C Settings
| Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulation Type
ControlInterrupt
- BYTE
Enable
- UINT
LowLevel
- UINT
HighLevel
SetGain
- BYTE
Setting
| Range: 0 to 3
ClearInterrupt
CalculateTemp
- UINT
EnableSensor
CalculateLux
- UINT
SampleSensor
ReadDataChannel
- BYTE
ColourChannel
- UINT
DisableSensor
SetIntegrationTime
- BYTE
Setting
| Range: 0 to 5
Sensor Settings
Integration Time
Gain
I2C Settings
| Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulation Type
ControlInterrupt
- BYTE
Enable
- UINT
LowLevel
- UINT
HighLevel
SetGain
- BYTE
Setting
| Range: 0 to 3
ClearInterrupt
CalculateTemp
- UINT
EnableSensor
CalculateLux
- UINT
SampleSensor
ReadDataChannel
- BYTE
ColourChannel
- UINT
DisableSensor
SetIntegrationTime
- BYTE
Setting
| Range: 0 to 5
Sensor Settings
Integration Time
Gain
I2C Settings
| Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulation Type
