Component: I2C Slave (Comms: Interface)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category Comms: Interface
I2C Slave component
Please click here to download the component source project: FC_Comp_Source_I2C_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Slave.fcfx
PIC16F1937 Examples
The slave device is connected to a bank of switches, the master device to a bank of LEDs. The value of the switches is passed to the master LEDs. Master Read Example
Slave Switches Example The slave device is connected to a bank of LEDs, the master device to a bank of switches. The value of the switches is passed to the slave LEDs. Master Send Example
Slave LEDs Example
Arduino Uno Examples
Example program showing how to use the I2C Slave on an AVR Arduino device. I2C Slave Arduino Uno Example
ECIO40P Examples
Example program showing how to use the I2C Slave on an ECIO40P device. Master Example
Slave Example
ReceiveByte
Receives a byte from the I²C bus. Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE Last
Used to signify the last byte when streaming incoming data. 0=Not last byte, 1=Last Byte
TransmitByte
Sends a byte on the I²C bus. Returns the acknowledge if any. 0 represents that data was acknowledged and 1 represents no acknowledge was detected.
- BYTE Data
Data byte to send on the I²C bus.
Check_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
Bus Settings
Channel selection
Baud Select
Baud rate to be used
Stop Delay
Slave Setttings
Slave Address
Mask
0 - don't care; 1 - perform match; So address of 0x30 and mask of 0xF0 will allow the slave to respond to addresses of 0x30, 0x31, 0x32, …, 0x3F
SDA
SCL
Label shown on the comms flasher on the simulation panel.
API
ReceiveByte
- BYTE Last
TransmitByte
- BYTE Data
Check_Status
Bus Settings
Channel selection
Baud Select
Stop Delay
Slave Setttings
Slave Address
Mask
SDA
SCL
API
ReceiveByte
- BYTE Last
TransmitByte
- BYTE Data
Check_Status
Bus Settings
Channel selection
Baud Select
Stop Delay
Slave Setttings
Slave Address
Mask
SDA
SCL
API
ReceiveByte
- BYTE Last
TransmitByte
- BYTE Data
Check_Status
Bus Settings
Channel selection
Baud Select
Stop Delay
Slave Setttings
Slave Address
Mask
SDA
SCL
API
