Component: K8055D (Third Party)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.3
Category Third Party
K8055D component
Support for the Velleman K8055 USB input/output board. Allows Flowcode to communicate with up to four K8055 boards, or to simulate them with interactive on-screen controls. All digital and analog I/O functions are supported.
Please click here to download the component source project: FC_Comp_Source_K8055D.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_K8055D.fcsx
GetCount
Read the value of the chosen counter for the currently selected board.
- INT Counter
The counter to read (1 or 2)
GetAnalogIn
Read analog input 1 or 2
- INT Input
Which input to read (1 ro 2)
- INT Return
SetAnalogOut
Sets the chosen analog output to the given value (0-255)
- BYTE Output
Which output to set the value for (1 ro 2)
- BYTE Value
Value to set (0-255)
SetDigitalOut
Sets the state of the output given by the output index (1 to 8)
- BYTE Out
Number of the output to set the value for
- BOOL Value
GetDigitalByte
Read all five inputs at once, returning them as a bit pattern in a byte. The upper three bits will always be zero.
- INT Return
ResetCount
Resets the chosen counter of the currently selected board.
- INT Counter
Which counter to reset (1 or 2)
GetDevices
Returns a value representing the available devices. Device is a binary value where bit(N) set = device at address (N) is connected.
- INT Return
Select
Selects the board address to send to and receive data from. Echos the address if the selection is valid. Returns -1 if there is no device available at that address.
- INT Address
The address off the board to be selected (0...3).
- INT Return
SetDigitalByte
Sets all eight digital outputs according to the individual bits of the Value parameter.
- BYTE Value
Value to send to the selected board.
GetDigitalIn
Read the individual input at the given index (1..5)
- INT Input
Which input to read (1 to 5)
- INT Return
SetCountDebounce
Set the amount of time allowed for switches to settle before being counted as a new event to count.
- INT Counter
Which counter to make a setting for (1 or 2)
- INT DebounceTime
Settling time for switch debouncing in milliseconds
Addr 0
Use software simulation to emulate a board connected at address 0.
Addr 1
Use software simulation to emulate a board connected at address 1.
Addr 2
Use software simulation to emulate a board connected at address 2.
Addr 3
Use software simulation to emulate a board connected at address 3.
Hardware
Scan
Request a scan of the currently connected hardware to detect what Velleman boards are connected and at what addresses. Where hardware is not detected at an addess, a System Panel simulation will be used instead where one has been requested in the properties.
GetCount
- INT Counter
GetAnalogIn
- INT Input
- INT Return
SetAnalogOut
- BYTE Output
- BYTE Value
SetDigitalOut
- BYTE Out
- BOOL Value
GetDigitalByte
- INT Return
ResetCount
- INT Counter
GetDevices
- INT Return
Select
- INT Address
- INT Return
SetDigitalByte
- BYTE Value
GetDigitalIn
- INT Input
- INT Return
SetCountDebounce
- INT Counter
- INT DebounceTime
Addr 0
Addr 1
Addr 2
Addr 3
Hardware
Scan
GetCount
- INT Counter
GetAnalogIn
- INT Input
- INT Return
SetAnalogOut
- BYTE Output
- BYTE Value
SetDigitalOut
- BYTE Out
- BOOL Value
GetDigitalByte
- INT Return
ResetCount
- INT Counter
GetDevices
- INT Return
Select
- INT Address
- INT Return
SetDigitalByte
- BYTE Value
GetDigitalIn
- INT Input
- INT Return
SetCountDebounce
- INT Counter
- INT DebounceTime
Addr 0
Addr 1
Addr 2
Addr 3
Hardware
Scan
GetCount
- INT Counter
GetAnalogIn
- INT Input
- INT Return
SetAnalogOut
- BYTE Output
- BYTE Value
SetDigitalOut
- BYTE Out
- BOOL Value
GetDigitalByte
- INT Return
ResetCount
- INT Counter
GetDevices
- INT Return
Select
- INT Address
- INT Return
SetDigitalByte
- BYTE Value
GetDigitalIn
- INT Input
- INT Return
SetCountDebounce
- INT Counter
- INT DebounceTime
Addr 0
Addr 1
Addr 2
Addr 3
Hardware
Scan
