Component: LED Array Template (LEDs)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
LED Array Template component
Create an evenly spaced array of LED indicators. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard LED component to change the style.
Please click here to download the component source project: FC_Comp_Source_LED_Array.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array.fcfx
Example program which uses the point graph macro and loops to create a knight rider effect using the LED array.
FC6 Icon.png LED KnightRider
Example program which reads an analogue value from an analogue input voltage and displays the reading in Binary on the LED array.
FC6 Icon.png LED Count
LEDs can be wired either active high or active low. The LED Array components have a property allowing you to configure which LED type your using.
LED Resistor Calculator Tool
Fc9-comp-macro.png BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
Fc9-u8-icon.png - BYTE Length
How many items to light up.
Fc9-comp-macro.png LEDOn
Turn on the selected LED.
Fc9-u8-icon.png - BYTE Index
Index of the LED to turn on.
Fc9-comp-macro.png AllOn
Turns on all elements
Fc9-comp-macro.png LEDOff
Turn off the selected led.
Fc9-comp-macro.png PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
The LED to show.
Fc9-comp-macro.png GetHandle
Retrieves the object handle of the indexed clone. Returns zero for out of range indexes.
Fc9-comp-macro.png WriteValue
Write a number which is presented on the LEDs in binary.
Fc9-u8-icon.png - BYTE Value
Provide a value to be written to the LEDs in binary
Fc9-comp-macro.png AllOff
Turns off all elements
Fc9-type-21-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Output Mode
Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Alignment
Which 3D axis to align the copies along.
Fc9-type-15-icon.png Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Fc9-type-7-icon.png Reverse
Reverse the direction of the LEDs.
Fc9-conn-icon.png Shape
Fc9-type-17-icon.png Target LED
Drag any LED component based on the 'LED base' onto the panel and select it here to use a custom LED design. When unconnected, you can choose a default geometric form instead.
Fc9-type-16-icon.png Shape
Shape for the LED when no target is selected.
Fc9-type-15-icon.png Width
Width of the LED shape.
Fc9-type-15-icon.png Height
Height of the LED shape.
Fc9-type-15-icon.png Depth
Depth of the LED shape.
Fc9-conn-icon.png Colors
Fc9-type-7-icon.png Same Color
Choose whether all LEDs should be the same color, or to set them individually.
Fc9-type-1-icon.png LED 0
The colour for LED 0 - or for all LEDs if that option is set.
Fc9-conn-icon.png Label
Fc9-type-16-icon.png Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Fc9-type-10-icon.png Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Fc9-type-1-icon.png Color
Color of the labels text.
Fc9-type-15-icon.png Scale
Sets the basic size (text height) of the labels.
Fc9-type-7-icon.png Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Fc9-type-16-icon.png Position
Set the position of the label relative to the component.
The LED to show.
The LED to show.
The LED to show.
