Variable Types
Variables can be specified as one of the following types:
| Type | Range | Bit Depth |
| BOOL | 0-1 | 1-bit unsigned variable |
| BYTE | 0-255 | 8-bit unsigned variable |
| INT | +/- 32768 | 16-bit signed variable |
| UINT | 0-65535 | 16-bit unsigned variable |
| LONG | +/- 21474836648 | 32-bit signed variable |
| ULONG | 0-4294967295 | 32-bit unsigned variable |
| String | 0-255 | 8-bit unsigned array. Default size is 20. |
| Floating point | -Inf to +Inf | 32-bit signed variable |
Type Range Bit Depth BOOL 0-1 1-bit unsigned variable BYTE 0-255 8-bit unsigned variable INT +/- 32768 16-bit signed variable UINT 0-65535 16-bit unsigned variable LONG +/- 21474836648 32-bit signed variable ULONG 0-4294967295 32-bit unsigned variable String 0-255 8-bit unsigned array. Default size is 20. Floating point -Inf to +Inf 32-bit signed variable
