Component: LED Mono (LED)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Category LED
LED Mono component
Please click here to download the component source project: FC_Comp_Source_LED_Mono_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Mono_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch and change the state of LED accordingly. LED Example
LED Resistor Calculator Tool
TurnOn
SetState
Sets the state of the LED, accounting for the polarity.
- BOOL State
1=On, 0=Off
TurnOff
LED Settings
Connection
Polarity
Component Label
Component label position
Label Colour
Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Pin label position
Shape
Colour
Style
TurnOn
SetState
- BOOL State
1=On, 0=Off
TurnOff
LED Settings
Connection
Polarity
Component Label
Label Colour
Show Pin Value
Pin label position
Shape
Colour
Style
TurnOn
SetState
- BOOL State
1=On, 0=Off
TurnOff
LED Settings
Connection
Polarity
Component Label
Label Colour
Show Pin Value
Pin label position
Shape
Colour
Style
TurnOn
SetState
- BOOL State
1=On, 0=Off
TurnOff
LED Settings
Connection
Polarity
Component Label
Label Colour
Show Pin Value
Pin label position
Shape
Colour
Style
