Editing Variables
Revision as of 09:32, 16 May 2013 by ReeceL (talk | contribs) (Created page with " '''Name Change''' The name of any selected variable can be changed by editing the 'Name of new variable' property. The change will affect all instances of the original var...")
Name Change
The name of any selected variable can be changed by editing the 'Name of new variable' property. The change will affect all instances of the original variable name in the Flowcode program.
Type Change
If a variable has not been used at all in the flowchart, then you can swap between any available type. If the variable has been used in the flowchart then you can swap between any of the types except String and Float.
Resizing strings
To resize the string open the variables window, select the string to resize and select 'edit' from the drop down menu, enter the new size for the array.
