| Author
Matrix TSL
| Version
2.2
| Category
Graphical Library
GLCD Bitmap Drawer ROM component
A component to simplify the process of drawing bitmap images to a graphical display. Stores up to 10 bitmap images inside ROM based look up tables. Compatible with 24-bit / 256 Colour / 16 Colour / Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap.fcfx
The Bitmap Drawer component must be linked to the graphical LCD using the gLCD Object property.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
Bitmap Drawer Demo
The bitmap files used in the example can be found here.
Bitmap Drawer Files
Here is another example which overlays several monochrome images to give the impression of animation. Shows a pair of eyes, which can randomly and momentarily look left, right or blink.
Bitmap Drawer Demo 2
Bitmap Drawer Files 2
GetHeight
| Returns the height of the loaded bitmap file in pixels.
- BYTE
BitmapIndex
| Selects from attached bitmaps. Range: 0-9
- UINT
GetWidth
| Returns the width of the loaded bitmap file in pixels.
- BYTE
BitmapIndex
- UINT
SetTransparentColour
| Sets the transparency colour, the colour that is not drawn when transparency is enabled.
- BYTE
R
- BYTE
G
- BYTE
B
Display_BMP
| Draws the bitmap image from ROM onto the display at the corrdinates X and Y.
- BYTE
BitmapIndex
- UINT
X
| X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT
Y
| Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE
Orientation
| 0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE
Transparency
| 0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE
Flip
| 0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Display_BMP_Fast
| Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Currently only supports colour displays.
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Transparency
LinkTo
ColourDisplay
| Automatically detects if the graphical LCD object is colour or monochrome
ROM Bytes
| Total number of ROM bytes used to store attached bitmap images.
Number of Bitmaps
| Number of bitmaps the component can store and draw to the LCD. Min 1 / Max 10
Bitmap 0
Bitmap File
| Bitmap file you wish to embed into the program. Compatible with .bmp files in the following formats: 24-Bit / 256 Colour / 16 Colour / Monochrome
File Colour Depth
| Number of bits per pixel. Currently the component only supports bitmap files with 1-bit or 24-bit colour depth.
File Length
| The number of bytes of ROM the bitmap file will consume. You can vie wthe number of ROM bytes available on your target device using the Device Helper component.
File Width
| Width of the bitmap file in pixels
File Height
| Height of the bitmap file in pixels
Data Offset
| Offset in the file where the bitmap pixel data starts
GetHeight
- BYTE
BitmapIndex
- UINT
GetWidth
- BYTE
BitmapIndex
- UINT
- BYTE
R
- BYTE
G
- BYTE
B
Display_BMP
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Orientation
- BYTE
Transparency
- BYTE
Flip
Display_BMP_Fast
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Transparency
LinkTo
ColourDisplay
ROM Bytes
Number of Bitmaps
Bitmap 0
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
GetHeight
- BYTE
BitmapIndex
- UINT
GetWidth
- BYTE
BitmapIndex
- UINT
- BYTE
R
- BYTE
G
- BYTE
B
Display_BMP
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Orientation
- BYTE
Transparency
- BYTE
Flip
Display_BMP_Fast
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Transparency
LinkTo
ColourDisplay
ROM Bytes
Number of Bitmaps
Bitmap 0
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
GetHeight
- BYTE
BitmapIndex
- UINT
GetWidth
- BYTE
BitmapIndex
- UINT
- BYTE
R
- BYTE
G
- BYTE
B
Display_BMP
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Orientation
- BYTE
Transparency
- BYTE
Flip
Display_BMP_Fast
- BYTE
BitmapIndex
- UINT
X
- UINT
Y
- BYTE
Transparency
LinkTo
ColourDisplay
ROM Bytes
Number of Bitmaps
Bitmap 0
Bitmap File
File Colour Depth
File Length
File Width
File Height
Data Offset
