Component: Linear Actuator (Mechatronics)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Category Mechatronics
Linear Actuator component
Creates a linear actuator that can be used with the various motor components via a coupling or gearbox.
Please click here to download the component source project: FC_Comp_Source_LinearActuator.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LinearActuator.fcfx
Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
- FLOAT Angle
Amount to rotate the shaft input in degrees
CheckLimits
Checks to see if either limit switch is active. Returns 1 if min switch is active, 2 if max switch is active, 3 if both switches are active else returns 0.
Actuator Properties
Translation Per Rev
Sets the amount of translation for each revolution of the input shaft. M4 = 0.7mm M5 = 0.8mm M6 = 1.0mm M8 = 1.25mm M10 = 1.5mm
Travel
Amount of travel in the linear actuator before hitting the end stops
Revolutions
Number of revolutions the actuator can travel
Colour
Sets the colour of the actuator and end stops
Output
Output connection for example an end tool or another linear slide and motor group.
Output Offset X
Distance along the X axis from the center of the coupling to the center of the output object.
Output Offset Y
Output Offset Z
Distance along the shaft from the center of the coupling to the center of the output object.
Limits
Limit Type
Controls if limit switches are available on the linear actuator.
Switch Polarity
Sets the active polarity of the input switches. Active low are often used to help reduce noise on the switch inputs.
Min Switch Pin
Pin connection used for the minimum limit switch
Max Switch Pin
Pin connection used for the maximum limit switch
Rotate
- FLOAT Angle
CheckLimits
Actuator Properties
Translation Per Rev
Travel
Revolutions
Colour
Output
Output Offset X
Output Offset Y
Output Offset Z
Limits
Limit Type
Switch Polarity
Min Switch Pin
Max Switch Pin
Rotate
- FLOAT Angle
CheckLimits
Actuator Properties
Translation Per Rev
Travel
Revolutions
Colour
Output
Output Offset X
Output Offset Y
Output Offset Z
Limits
Limit Type
Switch Polarity
Min Switch Pin
Max Switch Pin
Rotate
- FLOAT Angle
CheckLimits
Actuator Properties
Translation Per Rev
Travel
Revolutions
Colour
Output
Output Offset X
Output Offset Y
Output Offset Z
Limits
Limit Type
Switch Polarity
Min Switch Pin
Max Switch Pin
