Component: MIAC AllCode API (dsPIC) (AllCode)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category AllCode
MIAC AllCode API (dsPIC) component
MIAC AllCode. dsPIC version of the MIAC loaded with the AllCode firmware. Usefull for SCADA, Control or Test applications. Allows you to control the MIAC using the programming language of choice. Compatible with simulation / Bluetooth / Wifi / RS232 and RS485
Please click here to download the component source project: FC_Comp_Source_MIAC_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_AllCode_Component_Source.fcsx
Fc9-comp-macro.png CommsWrite
Writes a byte to the alt communications channel
Fc9-u8-icon.png - BYTE Data
Range: 0-255
Fc9-comp-macro.png WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
Fc9-u8-icon.png - BYTE Value
Range: 0-15 or 0b0000 to 0b1111
Fc9-comp-macro.png LCDPixel
Controls a single pixel on the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-119
Fc9-u8-icon.png - BYTE Y
Range: 0-49
Fc9-u8-icon.png - BYTE State
Range: 0-1
Fc9-comp-macro.png CardCreate
Attempts to create a specific file on the card. Returns 0 for success, 255 for no card or error.
Fc9-comp-macro.png CardDelete
Attempts to delete a specific file on the card. Returns 0 for success, 255 for no card or error.
Fc9-comp-macro.png LCDBitmap
Draws a bitmap file from the SD card onto the MIAC display
Range: 0-119
Range: 0-49
Range: 0-1
Fc9-comp-macro.png GetAPIVersion
Gets the API version of the Robot ARM Firmware
Fc9-comp-macro.png LCDNumber
Prints a number to the MIAC display starting from the current cursor position.
Fc9-s16-icon.png - INT Value
Range: -32678 - 32767
Fc9-comp-macro.png CardInserted
Checks to see if a card is present. Returns 0 for no card or 1 for card detected
Fc9-comp-macro.png ReadRTC
Reads a value from the real time clock module. Used for getting the time or date.
Fc9-u8-icon.png - BYTE Unit
0=Second 1=Minute 2=Hour 3=Day 4=Month 5=Year
Fc9-comp-macro.png CardOpen
Attempts to open a specific file from the card. Returns 0 for file found and opened, 239 for file not found and 255 for no card.
Fc9-comp-macro.png CommsRead
Reads a byte from the alt communications channel
Fc9-u8-icon.png - BYTE Timeout
Range: 0-255 : 0 = Don't wait / 1-255 = ms
Fc9-comp-macro.png ReadKey
Reads a keypress from the keypad.
Fc9-comp-macro.png WriteRTC
Writes a value to the real time clock module. Used for setting the time or date.
Fc9-comp-macro.png LCDBacklight
Controls the brightness of the LCD backlight.
Fc9-u8-icon.png - BYTE Brightness
Range: 0-100
Fc9-comp-macro.png WriteRelay
Allows a single relay to be switched on or off.
Range 1-4
0 = Off, 1 = On
Fc9-comp-macro.png LCDPrint
Prints a string to the MIAC display starting from the current cursor position.
Fc9-string-icon.png - STRING data
Range: 0-21
Fc9-comp-macro.png LCDLine
Draws a single pixel width line on the MIAC display
Fc9-u8-icon.png - BYTE X1
Range: 0-119
Fc9-u8-icon.png - BYTE Y1
Range: 0-49
Fc9-u8-icon.png - BYTE X2
Range: 0-119
Fc9-u8-icon.png - BYTE Y2
Range: 0-49
Fc9-comp-macro.png ReadInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
Fc9-comp-macro.png CardReadByte
Reads a byte from the open file.
Fc9-comp-macro.png WriteRelays
Allows all relays to be switched on or off in a single command.
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the open file. Returns 0 for success.
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png LCDRect
Draws a single pixel rectangle on the MIAC display
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Fc9-comp-macro.png ReadAnalogInput
Reads a single digital input.
Fc9-comp-macro.png CommsBaud
Sets the Baud rate of the alt communications channel
Fc9-u8-icon.png - BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
Fc9-comp-macro.png LCDOptions
Controls some of the LCD options
Fc9-u8-icon.png - BYTE Foreground
Range: 0-1
Fc9-u8-icon.png - BYTE Background
Range: 0-1
Range: 0-1
Fc9-comp-macro.png LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-u8-icon.png - BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
Fc9-comp-macro.png ReadDigitalInput
Fc9-comp-macro.png PWMConfig
Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
Range 0-1
Fc9-u16-icon.png - UINT Period
Range: 0-65535
Fc9-u8-icon.png - BYTE Scaler
Range: 0-3
Fc9-comp-macro.png PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-comp-macro.png PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
Range 0-5
Fc9-u16-icon.png - UINT Duty
Fc9-comp-macro.png LCDCursor
Sets the cursor position for the MIAC display
Range: 0-21
Range: 0-4
Allows a single transistor output to be switched on or off.
Range 1-4
0 = Off, 1 = On
Fc9-comp-macro.png LCDClear
Clears the MIAC display
Fc9-conn-icon.png Operating Mode
Fc9-type-16-icon.png API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
Fc9-type-7-icon.png Auto Detect
Fc9-type-14-icon.png Baud
Range: 0-255
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-100
Range 1-4
0 = Off, 1 = On
Range: 0-21
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-1
Range: 0-1
Range 0-1
Range: 0-65535
Range: 0-3
Range 0-5
Range: 0-21
Range: 0-4
Range 1-4
0 = Off, 1 = On
Range: 0-255
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-100
Range 1-4
0 = Off, 1 = On
Range: 0-21
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-1
Range: 0-1
Range 0-1
Range: 0-65535
Range: 0-3
Range 0-5
Range: 0-21
Range: 0-4
Range 1-4
0 = Off, 1 = On
Range: 0-255
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-100
Range 1-4
0 = Off, 1 = On
Range: 0-21
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-119
Range: 0-49
Range: 0-1
Range: 0-1
Range: 0-1
Range 0-1
Range: 0-65535
Range: 0-3
Range 0-5
Range: 0-21
Range: 0-4
Range 1-4
0 = Off, 1 = On
