Component: MIAC USB Slave API (PIC) (AllCode)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category AllCode
MIAC USB Slave API (PIC) component
Allows Matrix's MIAC PLC to be used as a PC peripheral controlled by Flowcode via a USB connection. Requires that the MIAC (PIC) has the USB Slave firmware downloaded to it.
Please click here to download the component source project: FC_Comp_Source_MIAC_Slave.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_Slave.fcsx
Firmware & USB Driver
The MIAC needs programming with the USB Slave firmware to function correctly with the MIAC USB Slave component.
Use the MIACprog tool to download the firmware .hex file to the MIAC.
File:MIAC USB Slave Firmware.zip
The MIAC USB Slave USB driver will need to be installed before Windows will correctly recognise the device and allow Flowcode to communicate correctly.
Controlled Using Flowcode
Here is a simple Flowcode program to toggle one of the transistor outputs on the MIAC USB Slave device. Remember to connect a linking wire between the (M) screw terminal to the (V+) screw terminal to allow the Transistor LEDs to light. MIAC USB Slave Here is an example of the high level MIAC USB Slave console.
Here is an example of the low level MIAC USB Slave console.
If the MIAC USB Slave component can see the MIAC USB Slave then you will able to select the instance via the Instance property.
Multiple MIAC USB slaves can be connected to a single PC and controlled by adding multiple MIAC USB Slave components each referring to their own instance of the hardware.
Controlled Using VB6 / VB2008
Files taken from the Locktronics Industrial sensor, actuator and control applications solution
File:VB Examples.zip
Controlled Using Labview
File:Labview Examples.zip
Command Table
Command Number Description Parameters Returns
1 Digital Input Channel (1-8) Input State (0-1)
2 Digital Multi Input N/A Input State 8-bit (0-255)
3 Analogue Input Channel (1-8) Input ADC Reading (0-255)
4 Read Keypad Buffer N/A Key Press (0-8 or 255)
5 Clear Keypad Buffer N/A N/A
6 Relay Control Channel (1-4)
Relay State (0-1)
N/A
7 Transistor Control Channel (1-4)
Transistor State (0-1)
N/A
8 Multi Output Control Output Value (0-255)
Output Mask (0-255)
N/A
9 Display Clear N/A N/A
10 Display Cursor Position X Coord (0-15)
Y Coord (0-3)
N/A
11 Display Number Number Low Byte (0-255)
Number High Byte (0-255)
N/A
12 Display String String Data N/A
13 PWM Enable Control PWM Channel (1-2)
Enabled (0-1)
N/A
14 PWM Duty Control PWM Channel (1-2)
Duty (0-255)
N/A
15 PWM Period Control Prescaler (0-2) N/A
16 PWM Overcurrent Check N/A Overcurrent State (0-1)
17 EEPROM Write Address (0-255)
Data (0-255)
N/A
18 EEPROM Read Address (0-255) Data (0-255)
19 CAN Set Data Num Bytes (0-8)
Data0 (0-255) Data1 (0-255) Data2 (0-255) Data3 (0-255)
Data4 (0-255) Data5 (0-255) Data6 (0-255) Data7 (0-255)
N/A
20 CAN Send Message ID Low Byte (0-255)
ID High Byte (0-7)
N/A
21 CAN Check Incoming N/A ID High
ID Low
22 CAN Get RX Data N/A Num Bytes (0-8)
23 Register Read Address Low Byte (0-255)
Address High Byte (0-255)
Register Data Byte (0-255)
24 Register Write Address Low Byte (0-255)
Address High Byte (0-255) Register Data Byte (0-255)
N/A
Component Source
The component source code is available here.
MIAC PIC Slave Component
LCDPrintString
Prints a string to the LCD on the MIAC.
- STRING Str
GetRegisterValue
Gets the value of the register specified on the MIAC
- UINT RegAddress
GetAnalogueInput
Returns the value for a specific analogue input on the MIAC slave.
- BYTE Input
LCDPrintNumber
Prints out a number to the display on the MIAC.
- INT Number
CANTx
Sends the Tx data with the ID specified in the form of a CAN message
- UINT CANID
GetKeypadBuffer
Returns a keypress from the keypress buffer, returns 255 if no keypress is available.
SetRegisterValue
Sets the value of the register specified on the MIAC
- UINT RegAddress
- BYTE Value
PWMSetPeriod
Sets the PWM period for the channel specified
- BYTE Prescaler
- BYTE Period
PWMOvercurrentCheck
Checks the PWM outputs to see if they are overcurrent
GetEEPROMData
Reads a byte from the EEPROM data memory
- BYTE Address
PWMControl
Sets the PWM channel specified to be enabled or disabled
- BYTE Channel
- BYTE Enable
CANSetTxData
Sets the LCD cursor position on the MIAC
- BYTE DataCount
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
GetDigitalInputs
Returns the value for a all 8 digital inputs on the MIAC slave.
SetEEPROMData
Writes a byte to the EEPROM data memory
- BYTE Address
- BYTE Data
CANGetRxData
Collects the data from the last received CAN message
- STRING Return
PWMSetDuty
Sets the duty cycle for the PWM channel specified
- BYTE Channel
- BYTE Duty
SetOutputBank
Controls the state of one of the transistor outputs on the MIAC slave.
- BYTE Mask
- BYTE Output_States
SetTransistorOutput
- BYTE Transistor
- BYTE State
GetDigitalInput
Returns the value for a specific digital input on the MIAC slave.
- BYTE Input
ClearKeypadBuffer
Destroys the contents of the keypad buffer.
LCDSetCursor
- BYTE x
- BYTE y
CANCheckRx
Checks to see if a CAN message has been received, if so the ID is returned
LCDClear
Clears the LCD display on the MIAC.
SetRelayOutput
Controls the state of one of the Relay outputs on the MIAC slave.
- BYTE Relay
- BYTE State
Instance
USB Slave Instance, if empty then is the MIAC slave firmware loaded, Is the MIAC slave driver installed, Is the MIAC connected and powered.
LCDPrintString
- STRING Str
GetRegisterValue
- UINT RegAddress
GetAnalogueInput
- BYTE Input
LCDPrintNumber
- INT Number
CANTx
- UINT CANID
GetKeypadBuffer
SetRegisterValue
- UINT RegAddress
- BYTE Value
PWMSetPeriod
- BYTE Prescaler
- BYTE Period
PWMOvercurrentCheck
GetEEPROMData
- BYTE Address
PWMControl
- BYTE Channel
- BYTE Enable
CANSetTxData
- BYTE DataCount
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
GetDigitalInputs
SetEEPROMData
- BYTE Address
- BYTE Data
CANGetRxData
- STRING Return
PWMSetDuty
- BYTE Channel
- BYTE Duty
SetOutputBank
- BYTE Mask
SetTransistorOutput
- BYTE Transistor
- BYTE State
GetDigitalInput
- BYTE Input
ClearKeypadBuffer
LCDSetCursor
- BYTE x
- BYTE y
CANCheckRx
LCDClear
SetRelayOutput
- BYTE Relay
- BYTE State
Instance
LCDPrintString
- STRING Str
GetRegisterValue
- UINT RegAddress
GetAnalogueInput
- BYTE Input
LCDPrintNumber
- INT Number
CANTx
- UINT CANID
GetKeypadBuffer
SetRegisterValue
- UINT RegAddress
- BYTE Value
PWMSetPeriod
- BYTE Prescaler
- BYTE Period
PWMOvercurrentCheck
GetEEPROMData
- BYTE Address
PWMControl
- BYTE Channel
- BYTE Enable
CANSetTxData
- BYTE DataCount
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
GetDigitalInputs
SetEEPROMData
- BYTE Address
- BYTE Data
CANGetRxData
- STRING Return
PWMSetDuty
- BYTE Channel
- BYTE Duty
SetOutputBank
- BYTE Mask
SetTransistorOutput
- BYTE Transistor
- BYTE State
GetDigitalInput
- BYTE Input
ClearKeypadBuffer
LCDSetCursor
- BYTE x
- BYTE y
CANCheckRx
LCDClear
SetRelayOutput
- BYTE Relay
- BYTE State
Instance
LCDPrintString
- STRING Str
GetRegisterValue
- UINT RegAddress
GetAnalogueInput
- BYTE Input
LCDPrintNumber
- INT Number
CANTx
- UINT CANID
GetKeypadBuffer
SetRegisterValue
- UINT RegAddress
- BYTE Value
PWMSetPeriod
- BYTE Prescaler
- BYTE Period
PWMOvercurrentCheck
GetEEPROMData
- BYTE Address
PWMControl
- BYTE Channel
- BYTE Enable
CANSetTxData
- BYTE DataCount
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
GetDigitalInputs
SetEEPROMData
- BYTE Address
- BYTE Data
CANGetRxData
- STRING Return
PWMSetDuty
- BYTE Channel
- BYTE Duty
SetOutputBank
- BYTE Mask
SetTransistorOutput
- BYTE Transistor
- BYTE State
GetDigitalInput
- BYTE Input
ClearKeypadBuffer
LCDSetCursor
- BYTE x
- BYTE y
CANCheckRx
LCDClear
SetRelayOutput
- BYTE Relay
- BYTE State
Instance
