Author
Matrix Ltd.
Version
2.1
Category
Comms: System
Modbus TCP Master component
Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is initialised and connected to a network before calling the ModbusMasterTCP component macros.
Please click here to download the component source project: FC_Comp_Source_ModbusTCP.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ModbusTCP.fcfx
Example master program to control the slave. The example sets coil address 0, clears coil address 0, reads an input register and outputs to the LCD. Be sure to set the IP address of the slave device at the top of the program. If you are simulating then use the IP address of the PC running the Slave simulation. Both programs can be simulated on the same PC using two instances of Flowcode.
Modbus TCP Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0 state to an LED connected to PortA. The input register is loaded with a value which is incremented on each Modbus transaction.
Modbus TCP Slave Example
Addressing
Data Type
Common name
Starting address
Ending Address
Flowcode Start Address
Flowcode End Address
Modbus Coils
Bits, binary values, flags
00001
10000
0
9999
Digital Inputs
Binary inputs
10001
30000
0
19999
Analog Inputs
Binary inputs
30001
40000
0
9999
Modbus Registers
Analog values, variables
40001
60000
0
19999
ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
The ID of the MODBUS slave
- UINT
RegAddress
Address: 0=40001, 1=40002, ...
- UINT
RegCount
Number of consecutive registers to read, starting from RegAddress
- BYTE
SetCoil
This command writes the contents of a discrete coil at the location CoilAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- BYTE
SlaveID
- UINT
CoilAddress
Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
- BYTE
CoilState
0=Off, 1=On
- BYTE
SetCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- BYTE
SlaveID
The ID of the MODBUS slave - Used for TCP to Serial forwarders
- UINT
CoilAddress
- UINT
CoilCount
Number of consecutive coils to try and read
- BYTE
CoilData
An array of bytes each containing 8 1-bit coil values
- BYTE
GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
- BYTE
Index
0=SlaveAddress, 1=FunctionCode/ExceptionCode, 2=DataBytes, 3=data0, 4=data1, ..
- BYTE
ReadCoils
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
GetResponseInt
Reads a 16-bit value from the last received response. The Index parametes specifies the byte index of the value to read back.
- BYTE
Index
3=data0, 5=data1, 7=data2, ..
- UINT
SetHoldingRegisters
This command writes the contents of several analogue output holding registers starting at the location RegAddress through to location RegAddress + RegCount . Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
Number of consecutive registers to write, starting from RegAddress
- UINT
RegValue
Array of values to send to the registers
- BYTE
SetHoldingRegister
This command writes the contents of a analogue output holding register at the location RegAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegValue
Value to send to the selected register
- BYTE
ReadAnalogInput
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
RegAddress
Input Address: 0=10001, 1=10002, 2=10003, ...
- UINT
RegCount
Number of consecutive inputs to read, starting from RegAddress
- BYTE
SetTCPAddress
Sets the address of the remote TCP Slave that we wish to control.
- STRING
Address
e.g. "192.168.1.1"
ReadDigitalInputs
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
- UINT
SlaveID
- UINT
DataAddress
- UINT
DataCount
- BYTE
Modbus TCP/IP Properties
LinkTo
Status
Shows the state of the network comms component to verify everything is configured correctly.
TCP/IP Port
Port used for network communications Range: 0-65535
Receive Buffer Size
Receive Timeout
Maximum time to wait for network reply, in mS
Simulation Properties
ReadHoldingRegister
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- BYTE
SetCoil
- BYTE
SlaveID
- UINT
CoilAddress
- BYTE
CoilState
0=Off, 1=On
- BYTE
SetCoils
- BYTE
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
CoilData
- BYTE
GetResponseByte
- BYTE
Index
- BYTE
ReadCoils
- UINT
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
GetResponseInt
- BYTE
Index
- UINT
SetHoldingRegisters
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- UINT
RegValue
- BYTE
SetHoldingRegister
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegValue
- BYTE
ReadAnalogInput
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- BYTE
SetTCPAddress
- STRING
Address
e.g. "192.168.1.1"
ReadDigitalInputs
- UINT
SlaveID
- UINT
DataAddress
- UINT
DataCount
- BYTE
LinkTo
Status
TCP/IP Port
Receive Buffer Size
Receive Timeout
ReadHoldingRegister
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- BYTE
SetCoil
- BYTE
SlaveID
- UINT
CoilAddress
- BYTE
CoilState
0=Off, 1=On
- BYTE
SetCoils
- BYTE
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
CoilData
- BYTE
GetResponseByte
- BYTE
Index
- BYTE
ReadCoils
- UINT
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
GetResponseInt
- BYTE
Index
- UINT
SetHoldingRegisters
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- UINT
RegValue
- BYTE
SetHoldingRegister
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegValue
- BYTE
ReadAnalogInput
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- BYTE
SetTCPAddress
- STRING
Address
e.g. "192.168.1.1"
ReadDigitalInputs
- UINT
SlaveID
- UINT
DataAddress
- UINT
DataCount
- BYTE
LinkTo
Status
TCP/IP Port
Receive Buffer Size
Receive Timeout
ReadHoldingRegister
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- BYTE
SetCoil
- BYTE
SlaveID
- UINT
CoilAddress
- BYTE
CoilState
0=Off, 1=On
- BYTE
SetCoils
- BYTE
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
CoilData
- BYTE
GetResponseByte
- BYTE
Index
- BYTE
ReadCoils
- UINT
SlaveID
- UINT
CoilAddress
- UINT
CoilCount
- BYTE
GetResponseInt
- BYTE
Index
- UINT
SetHoldingRegisters
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- UINT
RegValue
- BYTE
SetHoldingRegister
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegValue
- BYTE
ReadAnalogInput
- UINT
SlaveID
- UINT
RegAddress
- UINT
RegCount
- BYTE
SetTCPAddress
- STRING
Address
e.g. "192.168.1.1"
ReadDigitalInputs
- UINT
SlaveID
- UINT
DataAddress
- UINT
DataCount
- BYTE
LinkTo
Status
TCP/IP Port
Receive Buffer Size
Receive Timeout
