| Author
MatrixTSL
| Version
1.0
| Category
Comms: Interface
One Wire (DS2482) component
A One Wire master transciever controlled using I2C comms. Useful for microcontroller devices where One Wire communications timings are too tight to do reliably.
Please click here to download the component source project: FC_Comp_Source_One_Wire_DS2482_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_One_Wire_DS2482_I2C.fcfx
ReceiveByte
| Receives a byte from the one wire bus a bit at a time
- BYTE
TransmitByte
| Transmit a byte to the one wire bus a bit at a time
- BYTE
Command
SkipROM
| Performs a bus reset and the sends the SkipROM command byte
BusReset
| Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BOOL
MatchROM
| Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE
FamilyCode
- BYTE
SerialNumber
ScanBus
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE
GetDeviceCount
| Returns the number of devices found by the last ScanBus operation.
- BYTE
GetIDByte
| Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
- BYTE
Device
| Device ID - Range: 0 - NumDevices - 1
- BYTE
ByteIndex
| Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
- BYTE
Max Devices
| Controls the maximum number of devices that can be detected during a ScanBus. For each additional device we require 8 bytes to store the ROM ID. Default: 8 = 64 Bytes of RAM
I2C Properties
Device Address
| Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
Simulate Comms
ReceiveByte
- BYTE
TransmitByte
- BYTE
Command
SkipROM
BusReset
- BOOL
MatchROM
- BYTE
FamilyCode
- BYTE
SerialNumber
ScanBus
- BYTE
GetDeviceCount
- BYTE
GetIDByte
- BYTE
Device
- BYTE
ByteIndex
- BYTE
Max Devices
I2C Properties
Device Address
| Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
ReceiveByte
- BYTE
TransmitByte
- BYTE
Command
SkipROM
BusReset
- BOOL
MatchROM
- BYTE
FamilyCode
- BYTE
SerialNumber
ScanBus
- BYTE
GetDeviceCount
- BYTE
GetIDByte
- BYTE
Device
- BYTE
ByteIndex
- BYTE
Max Devices
I2C Properties
Device Address
| Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
ReceiveByte
- BYTE
TransmitByte
- BYTE
Command
SkipROM
BusReset
- BOOL
MatchROM
- BYTE
FamilyCode
- BYTE
SerialNumber
ScanBus
- BYTE
GetDeviceCount
- BYTE
GetIDByte
- BYTE
Device
- BYTE
ByteIndex
- BYTE
Max Devices
I2C Properties
Device Address
| Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
