Component: Air Quality (BME680) (BME680) (Environmental)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Environmental
Air Quality (BME680) component
A low power sensor capable of measuring air quality, pressure, temperature and humidiy. Connected to microcontroller using either I2C or SPI communications bus.
Please click here to download the component source project: FC_Comp_Source_Pressure_and_Air_BME680.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_and_Air_BME680.fcfx
Comms Type
Simulate Comms
Allows the communications to be simulated to allow for data to be sent via injector components,
I2C Comms
Channel selection
SDO Address Pin
The SDO pin specifies the least significant bit of the device address.
SDA
SCL
Baud Select
Baud rate to be used
Sensor Configuration
Humidity Oversampling
Controls the humidity oversampling setting
Temperature Oversampling
Controls the temperature oversampling setting
Pressure Oversampling
Controls the pressure oversampling setting
IIR Filter
Controls the filter coefficient used on the temperature and pressure data
Gas Wait Time
Gas sensor wait time multiplication factor
Comms Type
Simulate Comms
I2C Comms
Channel selection
SDO Address Pin
SDA
SCL
Baud Select
IIR Filter
Gas Wait Time
Comms Type
Simulate Comms
I2C Comms
Channel selection
SDO Address Pin
SDA
SCL
Baud Select
IIR Filter
Gas Wait Time
Comms Type
Simulate Comms
I2C Comms
Channel selection
SDO Address Pin
SDA
SCL
Baud Select
IIR Filter
Gas Wait Time
