| Author
Matrix TSL
| Version
1.0
| Category
Environmental
Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
Please click here to download the component source project: FC_Comp_Source_Pressure_Sensor_DPS310.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_DPS310.fcfx
ReadTemperature
| Reads the temperature measurement from the last SampleSensor macro
- FLOAT
ConfigurePressure
| Configures the pressure sensor sample rate and over sampling count
- BYTE
Rate
| Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
- BYTE
Oversample
| Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
ConfigureTemperature
| Configures the temperature sensor sample rate and over sampling count
- BYTE
Rate
- BYTE
Oversample
ReadPressure
| Reads the pressure measurement from the last SampleSensor macro
- FLOAT
SetMode
| Sets the operational mode of the sensor to be continous or one shot
- BYTE
Mode
ReadAltitude
| Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
- FLOAT
SampleSensor
| Checks to see if new data is available for temperature or pressure and collects it. Returns 0 if no new data is available Returns 1 for pressure, 2 for temperature and 3 for both.
- BYTE
ReadRegister
| Reads a byte from a register
- BYTE
Address
- BYTE
WriteRegister
| Writes a byte to a register
- BYTE
Address
- BYTE
Data
| Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
- BOOL
Device Settings
Device Address
Measurement Rate
Oversample Rate
Operational Mode
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
| No: Provides simulation using the panel component sliders. Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
ReadTemperature
- FLOAT
ConfigurePressure
- BYTE
Rate
- BYTE
Oversample
- BYTE
Rate
- BYTE
Oversample
ReadPressure
- FLOAT
SetMode
- BYTE
Mode
ReadAltitude
- FLOAT
SampleSensor
- BYTE
ReadRegister
- BYTE
Address
- BYTE
WriteRegister
- BYTE
Address
- BYTE
Data
- BOOL
Device Settings
Device Address
Measurement Rate
Oversample Rate
Operational Mode
| Channel selection
Baud Select
SDA
SCL
Stop Delay
Simulate Comms
ReadTemperature
- FLOAT
ConfigurePressure
- BYTE
Rate
- BYTE
Oversample
- BYTE
Rate
- BYTE
Oversample
ReadPressure
- FLOAT
SetMode
- BYTE
Mode
ReadAltitude
- FLOAT
SampleSensor
- BYTE
ReadRegister
- BYTE
Address
- BYTE
WriteRegister
- BYTE
Address
- BYTE
Data
- BOOL
Device Settings
Device Address
Measurement Rate
Oversample Rate
Operational Mode
| Channel selection
Baud Select
SDA
SCL
Stop Delay
Simulate Comms
ReadTemperature
- FLOAT
ConfigurePressure
- BYTE
Rate
- BYTE
Oversample
- BYTE
Rate
- BYTE
Oversample
ReadPressure
- FLOAT
SetMode
- BYTE
Mode
ReadAltitude
- FLOAT
SampleSensor
- BYTE
ReadRegister
- BYTE
Address
- BYTE
WriteRegister
- BYTE
Address
- BYTE
Data
- BOOL
Device Settings
Device Address
Measurement Rate
Oversample Rate
Operational Mode
| Channel selection
Baud Select
SDA
SCL
Stop Delay
Simulate Comms
