Component: Sense Hat (Raspberry Pi Hat)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Raspberry Pi Hat
Sense Hat component
A component to drive various features on the Raspberry Pi Sense Hat. Supported Features: 8x8 RGB LED / 5-Way Joystick
Please click here to download the component source project: FC_Comp_Source_RPI_SenseHat.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RPI_SenseHat.fcfx
A simple example to sample the joystick and output a fixed colour to all 8 x 8 RGB LEDs. Pressing up on the joystick outputs blue to the LEDs and pressing down outputs red.
FC6 Icon.png RPI Sense HAT
Fc9-comp-macro.png ReadJoystick
Reads the joystick Returns the direction as a bit field. 1 = Down / 2 = Right / 4 = Up / 8 = Click / 16 = Left
Fc9-comp-macro.png SetPixel
Seta the colour of a single pixel
Fc9-u8-icon.png - BYTE X
Fc9-u8-icon.png - BYTE Y
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-comp-macro.png SetAll
Sets all pixels to a specific colour
Fc9-comp-macro.png Initialise
Initialises the I2C peripheral ready for communications.
Fc9-conn-icon.png I2C
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Channel selection
Channel selection
Channel selection
