Component: Real Time Clock (ESP32) (Real Time Clock)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Real Time Clock
Real Time Clock (ESP32) component
Allows an ESP32 device to act as a RTC with NTP type server synchronisation. Requires a WIFI network connection with internet access to synchronise. Provides simulation using local PC system time.
Please click here to download the component source project: FC_Comp_Source_RTC_ESP32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RTC_ESP32.fcfx
A simple example that shows how to connect the ESP device to a network and synchronise the internal clock with an internet based NTP time server every hour.
ESP32 RTC NTP Example
The internal clock can drift over time and so it is important to sync regularily with the NTP time server.
For low power operations or when internet connectivity may be intermittent a 32.768KHz crystal can be used with the ESP32 device to improve the internal clock accuracy over time.
The crystal is fitted between pins IO32 and IO33 and must have 12pF capacitors to ground. The crystal must also be enabled by editing the sdkconfig file in the project compilation directory.
GetDateString
Collects the current date and returns it as a string. e.g. "DD/MM/YY" or "MM/DD/YY"
- BOOL USFormat
Select date format: 0=DD/MM/YY, 1=MM/DD/YY
- STRING Return
GetHours
Collects the current hour as a numeric value in the range of 0 - 23.
GetSecs
Collects the current second as a numeric value in the range of 0 - 59.
GetYear
Collects the year as a numeric value in the range of 0 - 99.
QueryTimeServer
Attempt to collect the local time from the selected time server. The ESP WIFI must be connected to a network with internet to allow this to work. Returns true if the time server synchronised correctly with the ESP.
- BOOL Return
ReadTime
- BYTE Unit
SetTime
Manually sets the current time. Useful for when WIFI / NTP commnication is not available.
- BYTE Hour
Hour ranging from 0 to 23
- BYTE Min
Minute ranging from 0 to 59
- BYTE Sec
Second ranging from 0 to 59
GetMins
Collects the current minute as a numeric value in the range of 0 - 59.
GetTimeString
Collects the current time and returns it as a string. e.g. "HH:MM" or "HH:MM:SS"
- BOOL IncludeSeconds
0=Dont Include Seconds, 1=Include Seconds in the String
- STRING Return
ReadDate
- BYTE Unit
SetDate
Manually sets the current date. Useful for when WIFI / NTP commnication is not available.
- BYTE Date
Day of the month ranging from 1 to 31
- BYTE Month
Month ranging from 1 to 12
- BYTE Year
Year ranging from 0 to 99
GetDate
Collects the day of the month as a numeric value in the range of 1 - 31.
SetTimeServer
Overwrites the default time server setting allowing for multiple time servers to be queried.
- STRING TimeServer
e.g. "pool.ntp.org"
GetMonth
Collects the month as a numeric value in the range of 1 - 12.
Configures the timeserver variable as well as sets the timezone offset in seconds.
SetUTCOffset
Allows the UTC Offset to be defined in seconds. e.g. for BST use 3600 or for UTC+2 use 7200 or for UTC-2 use -7200
- LONG UTCOffset
Time offset in seconds
Time Server
Default time server URL. Set as part of the initialise macro. Can be overridden using the SetTimeServer macro.
UTC Offset
Offset in seconds from UTC. Set as part of the initialise macro. Can be overridden using the SetUTCOffset macro.
Number of Retries
Sets the number of retries to connect to the SNTP server before giving up
GetDateString
- BOOL USFormat
- STRING Return
GetHours
GetSecs
GetYear
QueryTimeServer
- BOOL Return
ReadTime
- BYTE Unit
SetTime
- BYTE Hour
- BYTE Min
- BYTE Sec
GetMins
GetTimeString
- STRING Return
ReadDate
- BYTE Unit
SetDate
- BYTE Date
- BYTE Month
- BYTE Year
GetDate
SetTimeServer
- STRING TimeServer
e.g. "pool.ntp.org"
GetMonth
SetUTCOffset
- LONG UTCOffset
Time Server
UTC Offset
Number of Retries
GetDateString
- BOOL USFormat
- STRING Return
GetHours
GetSecs
GetYear
QueryTimeServer
- BOOL Return
ReadTime
- BYTE Unit
SetTime
- BYTE Hour
- BYTE Min
- BYTE Sec
GetMins
GetTimeString
- STRING Return
ReadDate
- BYTE Unit
SetDate
- BYTE Date
- BYTE Month
- BYTE Year
GetDate
SetTimeServer
- STRING TimeServer
e.g. "pool.ntp.org"
GetMonth
SetUTCOffset
- LONG UTCOffset
Time Server
UTC Offset
Number of Retries
GetDateString
- BOOL USFormat
- STRING Return
GetHours
GetSecs
GetYear
QueryTimeServer
- BOOL Return
ReadTime
- BYTE Unit
SetTime
- BYTE Hour
- BYTE Min
- BYTE Sec
GetMins
GetTimeString
- STRING Return
ReadDate
- BYTE Unit
SetDate
- BYTE Date
- BYTE Month
- BYTE Year
GetDate
SetTimeServer
- STRING TimeServer
e.g. "pool.ntp.org"
GetMonth
SetUTCOffset
- LONG UTCOffset
Time Server
UTC Offset
Number of Retries
