| Author
MatrixTSL
| Version
1.0
| Category
Wireless
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
Please click here to download the component source project: FC_Comp_Source_SRF_Component_v2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SRF_Component_v2.fcfx
SendString
| Send a string of data using the SRF Module
- STRING
Data
Wake
| Wake the SRF module. Includes a 10ms delay to allow radio to wake.
SendChar
- INT
Char
Sleep
| Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending)
SRFInitialise
| Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping.
ReceiveString
- BYTE
Timeout
- BYTE
NumBytes
- STRING
ReceiveChar
- BYTE
Timeout
- INT
Sleep Mode (ATSM)
| Defines which sleep mode will be used when calling the Sleep component macro.
| Serial comms data rate specified in bits per second.
| Onboard UART peripheral to use to perform serial commands. Software mode available but not recommended for receive applications unless combined with a pin interrupt.
TX
| Serial data transmit pin, output from the target microcontroller and should be connected to the RX pin of the module.
RX
| Serial data receive pin, input to the target microcontroller and should be connected to the TX pin of the module.
Sleep
Data Source
| Simulation data source used to allow the component to connect to COM port hardware or the the data API components.
COM Port
| Lists all the current available COM port hardware on your PC.
SendString
- STRING
Data
Wake
SendChar
- INT
Char
Sleep
SRFInitialise
ReceiveString
- BYTE
Timeout
- BYTE
NumBytes
- STRING
ReceiveChar
- BYTE
Timeout
- INT
Sleep Mode (ATSM)
TX
RX
Sleep
Data Source
COM Port
SendString
- STRING
Data
Wake
SendChar
- INT
Char
Sleep
SRFInitialise
ReceiveString
- BYTE
Timeout
- BYTE
NumBytes
- STRING
ReceiveChar
- BYTE
Timeout
- INT
Sleep Mode (ATSM)
TX
RX
Sleep
Data Source
COM Port
SendString
- STRING
Data
Wake
SendChar
- INT
Char
Sleep
SRFInitialise
ReceiveString
- BYTE
Timeout
- BYTE
NumBytes
- STRING
ReceiveChar
- BYTE
Timeout
- INT
Sleep Mode (ATSM)
TX
RX
Sleep
Data Source
COM Port
